Compression ratio on my setup
I have received several different answers and I want this put to rest. I have a 1992 ford efi 460 I'm putting d3ve heads on. What is my CR?
DieseLife- Posts : 14
Re: Compression ratio on my setup
Around 8:1
I've heard 8.7 and 9 and mid 9's lol
I'm trying to select a cam and impeller for my 18' Taylor jet boat I'm restoring
Factory is about 7.5 with most d3 heads and the non EFI pistons, EFI pistons have a slightly smaller dish
http://wallaceracing.com/cr_test2.php I came up with 8.8/1 CR with a 7cc dish ( which 1992 is said to have ) .030 in the hole with a 95cc chamber .041" gasket thickness.
supervel45- Posts : 4499
i did too. Confirmed my deck height from piston is .030, going to have to get a thinner head gasket though. Guess the guy gave me the wrong one it measures .05 not the .041 i wanted. Thanks fellas just wanted to reassure my calculations were correct
What did you use for the combustion chamber cc?
actually i lied i got 9:1
4.36 bore (stock)
3.85 stroke
4.5 HG bore diameter
.041 HG
92cc
-7cc dish
.030 deck height
4.36 bore (stock)
3.85 stroke
.041 HG
92cc
-7cc dish
.030 deck height
I used 95cc for the head chamber size, 4.40" for the gasket with .041" thickness .030 for deck height or in the hole. Came out to 8.88 CR.
» Compression ratio?
» compression ratio ???? 460
» compression ratio....what gas to use?
» Compression ratio
» Compression ratio
