alky guys need info
gmsmkr
alky guys need info Empty alky guys need info
Post  gmsmkr April 15th 2015, 8:46 pm
Alky guys I need to pic yalls brain and teach me about it... I just picked up a rons flying toilet with a dommy flange.
Can this be converted to gas?
What is the up keep on the alky combo?
Will it respond to a pump gas Compression combo?
How to tune with alky?
Basically I need to learn everything about it I dont plan on making the switch this year but anything could happen.....please teach me and supply all info your willing to share.  Thanks, MP
gmsmkr
gmsmkr
alky guys need info Empty Re: alky guys need info
Post  cool40 April 15th 2015, 9:18 pm
You Can run gas but learning with alky would be much better. Do all the reading you can on the subject first. Very Happy upkeep is easy also and the best advice i can give you i got from here. KY jelly said dont start it just to hear it run every day! Laughing best way to avoid milking the oil is keep the barrel valve lean as possible,always heat it up to at least 180* when you start it and kill it with the fuel shut off cable.
Post  gmsmkr April 15th 2015, 10:02 pm
thanks, I'm reading everything I can
gmsmkr
gmsmkr
Post  cool40 April 15th 2015, 10:42 pm
Fabio knows plenty about the rons injection if he ain't inhaled too much q16 to remember! Razz
Post  69F100 April 15th 2015, 11:04 pm
I run a primer plus under my alky carb for firing it up and moving it around you can run it under the tolit also. That way you don't have to wait to get the engine up to temp before shutting it down plus I warm my engine with it also.
Post  Wheelie58 April 16th 2015, 5:04 am
You can find lots of good info at KillerRONS.com
James has posted several frequently asked questions and topics regarding injection.
I have been running Rons injection for many many years, but never attempted gas.
Some of the basic "musts" include a front mounted fuel tank, or surge tank setup, an EGT monitor gauge and if on alky, a primer system.
Call any time if you want to talk Toilets. You can see pictures of my Triple Toilet combo on my web site.
Keith
678-458-2033
KeithFulpMotorsports.com
Wheelie58
Wheelie58
Post  gmsmkr April 16th 2015, 10:01 am
Thanks for all the help and Web site I am looking into primer stuff
gmsmkr
gmsmkr
Post  richter69 April 16th 2015, 10:09 am
Ky ran his on q16, it was finiky tho. Pump gas? I wouldnt even attempt it.... The mech inj is too crude to get the af right imo.
Just run plain methanol through it....
Post  gmsmkr April 16th 2015, 5:25 pm
Ok I been looking into belt drive pumps so..... I'm not making 1000+ HP right now can I get a pump that I can use as I grow in power?
(Also I'm going to stay with meth) as i have been told to do. Do my injector nozzles need to be low or high on my intake runners my nitrous nozzles are low do they need to be above my injection or what?
I'm going to pick up another intake to start pluming stuff while I gather other parts for this deal I'm just getting a heads up on where stuff needs to be thanks
gmsmkr
gmsmkr
Post  Wheelie58 April 16th 2015, 5:37 pm
Pump size...
A 0-1/2 pump will get you to 1000 hp.
Over 1000, you will need a #1.
If the pump is too big, you simply put a high speed bypass on it to dump the extra volume.
I have successfully used a #1 on 800 through 1200 HP.
The Rons black pump is pretty well bullet proof, if you use Manhattsn Oil top lube.
KillerRONS gives you nozzle placement info, but put them relatively close to the intake flange. If you use a Trick Flow tunnel ram, right above the nitrous boss.
Keith
Wheelie58
Wheelie58
Post  gmsmkr April 16th 2015, 5:44 pm
Thanks Keith I was looking at the black pumps and i found the HP rating on them so I think I will start looking for a #1 pump.
Is there anything I need to watch for buying a used pump?
The web site you sent me too has some great info its just a lot to take in ....lol
gmsmkr
gmsmkr
Post  69F100 April 16th 2015, 7:46 pm
gmsmkr wrote:Thanks Keith I was looking at the black pumps and i found the HP rating on them so I think I will start looking for a #1 pump.
Keep a eye out on Ron's site he has use stuff on sale a lot of time you might find one there.
Post  gmsmkr April 16th 2015, 8:23 pm
Thanks for the heads up Jim I will keep a check on it also
gmsmkr
gmsmkr
Post  KY JELLY April 17th 2015, 11:04 pm
They will run on gas . You have to get smaller nozzles and the biggest issue i got into was you have to run the barrel valve richer than what is an ideal idle tune on gas to keep from having a dead spot when you flat foot it . Its not that hard to tune it in , but if you are running Q16 its gets expensive real quick idling up to the staging lanes with a rich idle lol.
KY JELLY
KY JELLY
Post  David Cole April 17th 2015, 11:13 pm
Just wanted to add something about the pumps. With a Ron's black gear style pump you can take a 0 1/2 pump and have it easily converted to a #1 and vice versa. I had my 0 1/2 upgraded to a 1 for my current combo.
For a beginner learning curve I would be more apt to use a 0 1/2 to start as long as you are under 1000 hp. Then you don't have to run a high speed bypass. Just one variable to remove until you get a handle on the tune. When you move up in power you can have the pump upgraded to the larger size and add a high speed bypass.
Post  gmsmkr April 18th 2015, 10:19 am
Thanks Dave that is good to know I need everything as simple as can be for a beginner on this.
Ky...I don't think I have the experience to try for pump gas right now I'm just going to try and keep it simple so I can learn it better
gmsmkr
gmsmkr
