I finally fired my 460..
+6
61coon
SandHillsHillbilly
kim
10 posters
I finally fired my 460.. Empty I finally fired my 460..
Post  jasonf April 22nd 2015, 10:29 pm
I finally finished my engine run stand and fired my 460 tonight. It has an unknown solid roller cam. tfs street heads, tfs track heat intake converted to efi (from TEA), Holley HPefi with a 58 tooth crank trigger, Price Motorsports cam sensor, 48 lb injectors,  LS ignition coils.
I finally fired my 460.. 20150422_211642_resized_zps4zah2g8f
Check out that 1/4" thick starter plate from KFM.
I finally fired my 460.. 20150422_211657_resized_zpst6dblxyi
I finally fired my 460.. 20150422_211712_resized_zpsr51wsrqv
It starts loading up in the 1-4 side after about 30 seconds but I have done ZERO tuning. This was just the second start.
I finally fired my 460.. Th_460%20start_zpsmaq6u6ru
I finally fired my 460.. Empty Re: I finally fired my 460..
Post  res0rli9 April 22nd 2015, 10:36 pm
Cool
Post  kim April 22nd 2015, 10:50 pm
loading one side, other side lean, 02 input crossed.
kim
Post  SandHillsHillbilly April 23rd 2015, 1:17 am
Can you post some pics of the trigger wheel and trigger mount?
Who is TEA?
SandHillsHillbilly
SandHillsHillbilly
Post  cool40 April 23rd 2015, 1:20 am
Cool Cool Cool i like it!
Post  jasonf April 23rd 2015, 9:45 am
SandHillsHillbilly wrote:Can you post some pics of the trigger wheel and trigger mount?
Who is TEA?
TEA is Total Engine Airflow. They are part of the TrickFlow/Summit companies and are located in the back corner of Trick Flow. They were the only people I could find that would machine the injector holes for a reasonable price and actually had experience doing it. There is other companies out there that do conversions but the prices are pretty expensive.
http://www.totalengineairflow.com/
I had a MSD crank trigger setup but with the larger Innovators balancer leaves no room. IW has their own bracket system but it still wouldn't fit the correct Hall effect sensor so fab work would have been needed regardless.
I finally fired my 460.. 20150306_084845_zpsnwlq1mht
So I made a new mount for the Holley sensor from some 3/8" alum angle. I used the bottom mounting hole for the MSD bracket and drilled the second hole where the slot is. It is non adjustable but that is what I was after anyways.
I finally fired my 460.. 20150408_134001_resized_zpsdsfgda4g
Post  61coon April 23rd 2015, 9:56 am
That's an awesome build Jason. I really like the fuel injection part! Sounds good too. Are you gonna dyno this engine or just let it eat?
61coon
61coon
Post  jasonf April 23rd 2015, 9:58 am
61coon wrote:That's an awesome build Jason. I really like the fuel injection part! Sounds good too. Are you gonna dyno this engine or just let it eat?
I need to learn the Holley system and get it running properly before putting it in my 56. Then maybe I will do a chassis dyno, depends on funds. The car doesn't have any cage as it is just a street car so it is not really a big deal at this time. Driveability is.
Post  jasonf April 23rd 2015, 10:05 am
Another view of the crank trigger.
I finally fired my 460.. 20150423_090118_zps5x3wjl6l
I also seem to have a clearance problem I will need to deal with.
I finally fired my 460.. 20150423_090230_zps1x22kix0
Post  61coon April 23rd 2015, 10:10 am
That fuel injection will be real nice on the street. What trans are you gonna go with?
61coon
61coon
Post  jasonf April 23rd 2015, 10:52 am
61coon wrote:That fuel injection will be real nice on the street. What trans are you gonna go with?
Lentech AOD
Post  61coon April 23rd 2015, 11:44 am
Lentech AOD
Love it! Cool
61coon
61coon
Post  cletus66 April 23rd 2015, 2:37 pm
Cool setup, and I really like that stand. Cool
Post  SandHillsHillbilly April 23rd 2015, 7:41 pm
Well crap! That answers that question about the crank trigger. I was hopping to mount the trigger wheel on the back side of the balancer.
I am running same serp belt setup but with full compliment with AC and power steering. Will just have to space everything out the thickness of the trigger wheel.
SandHillsHillbilly
SandHillsHillbilly
Post  FalconEh April 23rd 2015, 8:00 pm
cheers VERY Cool
The sweet sound of music.
Post  billandlori April 23rd 2015, 10:51 pm
Very nice job Jason!! That thing sounds sweet!!
Bill
Post  gmsmkr April 24th 2015, 7:52 am
Sounds good should be alot of fun on the streets
gmsmkr
gmsmkr
Post  jasonf April 24th 2015, 3:00 pm
SandHillsHillbilly wrote:Well crap! That answers that question about the crank trigger. I was hopping to mount the trigger wheel on the back side of the balancer.
Is yours an internally balanced unit? If so you can slice the spacer in half. cut out 1/8" and sandwich the wheel in between the 2 halfs.
I finally fired my 460.. 460%20crank%20trigger_zpsekvxla1p
I finally fired my 460.. 460%20crank%20trigger%202_zpse70tvk2j
http://forums.holley.com/showthread.php?2545-Custom-60-2-Crank-Trigger-Kit
Post  jasonf April 24th 2015, 3:02 pm
Do you have a picture of your accessories? I need to make something as billet specialties is a bit out of my price range.
Post  gmsmkr April 24th 2015, 4:20 pm
Hey Jason I have some pulleys off a efi 460 if you need them just pay shipping......pm me if interested
gmsmkr
gmsmkr
Post  SandHillsHillbilly April 25th 2015, 7:25 am
Yeah I have seen Danny's mount before. And seeing the underside pic there looks like tons of room to mount the trigger wheel to back of balancer. Most balancers have dual bolt patterns in the hub. I thought of using the unused holes to mount trigger wheel. I am running external balance. My plan is/was to use a Kasse Timing pointer in the stock location and an Innovators West crank trigger sensor mount on the driver's side. I will have to modify the mount to use an LS crank sensor. If I find the radiator hose interferes too much I will have to change to an IW's combination timing pointer and sensor mount on passenger side.
Either way the sensor is going to have to be in the bottom half to the trigger wheel. I need to get off my lazy butt and mount a block to a stand so I can mock everything up.
I finally fired my 460.. 932
I finally fired my 460.. Th_sensor1I finally fired my 460.. Th_sensor2I finally fired my 460.. Th_sensor3I finally fired my 460.. Th_sensor4
SandHillsHillbilly
SandHillsHillbilly
Post  SandHillsHillbilly April 25th 2015, 7:32 am
I don't have any specific pic, but I may have some random pics that may help you.
Check this album:
http://www.supermotors.net/registry/9046/32533
Also check Trent's pages he may have some that will help.
http://www.ncspecialties.com/autobody/compressorbracket/index.htm
I finally fired my 460.. Airmount009
To duplicate the factory may prove futile. Hunt the salvage and pull a part yards for F or E 350s. The E350s have the nicer Saginaw power steering pumps. I will keep my ear to the ground for you. If I come across a set I will let you know.
SandHillsHillbilly
SandHillsHillbilly
Post  jasonf April 25th 2015, 12:29 pm
I will probably just build something. I will need different stages as I add the A/C later.
