SBF stuff
+7
LivermoreDave
whitefield
stanggt
Larry Williams
11 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
SBF stuff
I know this is a BBF forum and I have those but I also have a 420 stroker sbf that I need some hook-ups on. Who on here is good with those also. I need to send my heads out for a bad-azz valve job and spring set-up for a custom roller nos cam that needs to be made for a 250 hit as well as maybe some porting on the intake and heads even though the heads are cnc ported already. would like to make 600 ish hp and some good torque on the motor and then spray it.
stanggt- Posts : 494
Re: SBF stuff
which heads have you? I made 688 hp on the dyno with a 393 w
Larry Williams- Posts : 884
Re: SBF stuff
Which heads? Which intake? Doesn't take much port at all to make 600.
whatbumper- Posts : 3024
Re: SBF stuff
easy deal, what heads? cam? blah blah blah?
Re: SBF stuff
pro comp intake, copy of the vic jr intake and Pro-comp alum. 220 CNC heads. The cam I will need someone to cut me a good roller grind NOS compatible. Heads need valves and springs yet. 2.08/1.60 compression with these heads and the -12cc dish srp pistons will be about 11-1 maybe a tick more. I still need to figyre it out to a T
Re: SBF stuff
stanggt wrote:pro comp intake, copy of the vic jr intake and Pro-comp alum. 220 CNC heads. The cam I will need someone to cut me a good roller grind NOS compatible. Heads need valves and springs yet. 2.08/1.60
What compression ? Have the intake and heads port matched and have both ported. What block and what is the bore size ?
whitefield- Posts : 2244
Re: SBF stuff
its a 79 351w truck block, .040 over and 4.100 stroke, Eagle 4340 crank with eagle H-beams and SRP -12cc forged pistons. Professional Products SFI damper and sfi flexplate all balanced together. Main girdle with Canton pan and windage tray.
Re: SBF stuff
With only a 250 shot I would just cam the engine. The small block pro comp are better performers than their big block counter parts. Still not the greatest though. Put a 255 265 on a 108 in it. That grind will run in anything and make good power. Then when you have money for a set of heads that deserve a good cam buy a good custom one at that time.
Re: SBF stuff
I have a set of heads on my shelf that will make 675-700 with that short block with the right cam. We made 675 at 9.5:1 with them on about 50 less cubes.
But in all honesty I would call up bullet cams or someone and just get a decent NA cam.
Re: SBF stuff
Procomp/RHS arent they the same company? Anyways these heads are someone else CNC program and thats all I know about them. They look pretty nice to start with and figure someone could take them and touch them up a bit and put a nice race valve job into them. Not looking for a amax effort deal just a stout 600-700 na then spray it some. What heads would u suggest, maybe can afford some nice used ones for the right price and sell these casting.IDT-572 wrote:With only a 250 shot I would just cam the engine. The small block pro comp are better performers than their big block counter parts. Still not the greatest though. Put a 255 265 on a 108 in it. That grind will run in anything and make good power. Then when you have money for a set of heads that deserve a good cam buy a good custom one at that time.
Re: SBF stuff
what heads might those be? looking to sell them?whatbumper wrote:I have a set of heads on my shelf that will make 675-700 with that short block with the right cam. We made 675 at 9.5:1 with them on about 50 less cubes.
Re: SBF stuff
AFR 220 Renegade looks like a great head as well as TrickFlow 225 HighPorts. The AFR outflows the TF by 3cfm @.700 lift. The AFR flows a total of 340 @ .800 lift @28in H2o. Any dealer for these heads please pm me a price.
Re: SBF stuff
stanggt wrote:AFR 220 Renegade looks like a great head as well as TrickFlow 225 HighPorts. The AFR outflows the TF by 3cfm @.700 lift. The AFR flows a total of 340 @ .800 lift @28in H2o. Any dealer for these heads please pm me a price.
I just bought a set of AFR's from TRE performance here is a link and the best prices.
http://treperformance.com/
Summit and everyone else are 4 to 6 weeks out on AFR heads.
Cam it for all you can on motor and then whatever you get on the hose is a plus
Duration @.050 in the mid 260s to mid 270 range .690 to .710 lift and no more than .720 108 or 107 lobe seperation and install on a 106 or 104 intake centerline if you go with the AFR heads. My opinion
Re: SBF stuff
thanks for the link, good price there. You runnung a stroker SBF?whitefield wrote:stanggt wrote:AFR 220 Renegade looks like a great head as well as TrickFlow 225 HighPorts. The AFR outflows the TF by 3cfm @.700 lift. The AFR flows a total of 340 @ .800 lift @28in H2o. Any dealer for these heads please pm me a price.
Re: SBF stuff
stanggt wrote:what heads might those be? looking to sell them?whatbumper wrote:I have a set of heads on my shelf that will make 675-700 with that short block with the right cam. We made 675 at 9.5:1 with them on about 50 less cubes.
I have big TFS-R heads but for the price of those AFR's I would just get them. I will sell you mine but I would have to get about the same price as the new AFR's. the port work and valve job I have in mine is not cheap. Good luck!
Re: SBF stuff
stanggt wrote:thanks for the link, good price there. You runnung a stroker SBF?whitefield wrote:stanggt wrote:AFR 220 Renegade looks like a great head as well as TrickFlow 225 HighPorts. The AFR outflows the TF by 3cfm @.700 lift. The AFR flows a total of 340 @ .800 lift @28in H2o. Any dealer for these heads please pm me a price.
Yes I have a pump gas 10.5:1 205 AFR Headed 393W that I mix 93 with 110 , but the last time out it had straight 93 in it and ran its best time with the current compression ,carb ,and cam combo. Good luck and glad to help
Re: SBF stuff
whitefield wrote:stanggt wrote:thanks for the link, good price there. You runnung a stroker SBF?whitefield wrote:stanggt wrote:AFR 220 Renegade looks like a great head as well as TrickFlow 225 HighPorts. The AFR outflows the TF by 3cfm @.700 lift. The AFR flows a total of 340 @ .800 lift @28in H2o. Any dealer for these heads please pm me a price.
what times are u running? What kinda power u making ?
Re: SBF stuff
what kinda power are u making and what times are you running?
Re: SBF stuff
stanggt wrote:what kinda power are u making and what times are you running?
Not sure on the power but in the 1/8th mile with current set up it has gone 6.80 at 101 mph with 1.44 60ft 3000lb car on 275 /60/15 m/t drag radials 4.11 gear 5000 8'' converter. That is going up hill! lol 1/4 Mile was 10.76 at 126 mph. This is with dish pistons with 2 valve reliefs and the piston down in the hole .007.
With the old cam and 950 carb it went 6.90 at 104mph 1/8th mile and wasn't consistant.
First set up with flat tops went 6.72 at 103mph 1/8 with 4500 9.5 converter with above cam and carb
Re: SBF stuff
^^^^ Itll be faster with his new jockey...........
Re: SBF stuff
sweet, ordering those AFR225 this week for my 420, will put compression at 11.14 on this motor with zero deck and -12cc dish. then will call bullit for a camshaft and lifters. should be fun. hope the convertable can handle it!!!
Re: SBF stuff
richter69 wrote:^^^^ Itll be faster with his new jockey...........
I hope your right I am ready to go Racin
Re: SBF stuff
stanggt wrote:sweet, ordering those AFR225 this week for my 420, will put compression at 11.14 on this motor with zero deck and -12cc dish. then will call bullit for a camshaft and lifters. should be fun. hope the convertable can handle it!!!
It will be a fun ride for sure! good luck and keep us posted
Re: SBF stuff
she's better to look at for sure........
Re: SBF stuff
will do,thanks for info. LOVE this site, you guys are awesomewhitefield wrote:stanggt wrote:sweet, ordering those AFR225 this week for my 420, will put compression at 11.14 on this motor with zero deck and -12cc dish. then will call bullit for a camshaft and lifters. should be fun. hope the convertable can handle it!!!
» looking for 429/460 stuff
» BIG STUFF 3 ????
» Anyone been doing any car stuff?
» Delete
» Some new stuff
» BIG STUFF 3 ????
» Delete
» Some new stuff
Page 1 of 3
