SBF stuff
+7
LivermoreDave
whitefield
stanggt
Larry Williams
11 posters
Page 2 of 3
Page 2 of 3 • 1, 2, 3
fired it up!!!!!
well its been awile but I finally fired up the 420 and boy oh boy does it sound bad a$$. very responsive and crisp to the throttle. Ended up going with the new AFR Renegade 58cc heads with a super victor intake and an hp1000 cfm holley carb. 2 inch Primary kooks headers with 3.5inch collectors. Bullit did the cam but I think its a moderate one, not all out as I am going to drive it some on the street. The cam card reads dur@.050 is 264in/271ex on a 108 separation with .668/.668 lift solid roller lashed at .026. electric water pump so only running an alt off the crank. don't have the extra cash to have it dynode as I have to build a trans and rearend and 4 wheel disc brake setup and etc. sounds like it will make some big power for sure. any thoughts?
stanggt- Posts : 494
Re: SBF stuff
Compression and which afr heads ?stanggt wrote:well its been awile but I finally fired up the 420 and boy oh boy does it sound bad a$$. very whetresponsive and crisp to the throttle. Ended up going with the new AFR Renegade 58cc heads with a super victor intake and an hp1000 cfm holley carb. 2 inch Primary kooks headers with 3.5inch collectors. Bullit did the cam but I think its a moderate one, not all out as I am going to drive it some on the street. The cam card reads dur@.050 is 264in/271ex on a 108 separation with .668/.668 lift solid roller lashed at .026. electric water pump so only running an alt off the crank. don't have the extra cash to have it dynode as I have to build a trans and rearend and 4 wheel disc brake setup and etc. sounds like it will make some big power for sure. any thoughts?
whitefield- Posts : 2244
Re: SBF stuff
11.14 on compression with the afr 225 renegades. they flow 330 @ .700 lift and 340 @ .800
Re: SBF stuff
I would say around 600 to 620 maybe a little more but would need more cam and compression to make 650 to 700 in my opinion. Glad you got it going post some video of if you can or pics.
Re: SBF stuff
If tuned well I would guess between 650-675. If the cam events were right on then it may make more due to compression. It's definitely an all motor cam as is. I don't think it will take a 250 shot with that cam. Not very good cam timing events for a large dose like that.
whatbumper- Posts : 3024
Re: SBF stuff
Unless I overlooked a post that included an aftermarket engine block, at the horsepower levels you seek and then add an additional 250 horsepower, maybe an quality aftermarket engine block should be on your list!
Dave.
Dave.
LivermoreDave- Posts : 972
Re: SBF stuff
we did degree the cam to the 104 cl that they told me to. I agree with the cam. I know there is more to be had with a bigger camshaft but will put some time on the motor with the one I have and then call bullit up and have them cut me a new one. If I could get about 700hp out of this motor with a cam swap then I may just forget the nos and have it all motor.whatbumper wrote:If tuned well I would guess between 650-675. If the cam events were right on then it may make more due to compression. It's definitely an all motor cam as is. I don't think it will take a 250 shot with that cam. Not very good cam timing events for a large dose like that.
Re: SBF stuff
the cam in my 321 is a good bit bigger, I wouldnt hit that with much more than a 175 or so.
who spec'd the cam?
who spec'd the cam?
Re: SBF stuff
I'm not saying its a bad cam don't get me wrong here. It probably is fine for NA application but it is not a nitrous cam especially on 104cl.stanggt wrote:we did degree the cam to the 104 cl that they told me to. I agree with the cam. I know there is more to be had with a bigger camshaft but will put some time on the motor with the one I have and then call bullit up and have them cut me a new one. If I could get about 700hp out of this motor with a cam swap then I may just forget the nos and have it all motor.whatbumper wrote:If tuned well I would guess between 650-675. If the cam events were right on then it may make more due to compression. It's definitely an all motor cam as is. I don't think it will take a 250 shot with that cam. Not very good cam timing events for a large dose like that.
Re: SBF stuff
X2 its a N/A cam and 100 shot is all I would want to blow through it . But again it will be fun and you can let us on the out side looking in know how it does.whatbumper wrote:I'm not saying its a bad cam don't get me wrong here. It probably is fine for NA application but it is not a nitrous cam especially on 104cl.stanggt wrote:we did degree the cam to the 104 cl that they told me to. I agree with the cam. I know there is more to be had with a bigger camshaft but will put some time on the motor with the one I have and then call bullit up and have them cut me a new one. If I could get about 700hp out of this motor with a cam swap then I may just forget the nos and have it all motor.whatbumper wrote:If tuned well I would guess between 650-675. If the cam events were right on then it may make more due to compression. It's definitely an all motor cam as is. I don't think it will take a 250 shot with that cam. Not very good cam timing events for a large dose like that.
Re: SBF stuff
I wont spray it with this cam. Will run it a bit and when I want more then I will have them grind me a new one. Next on the to do list is build my trans. I have a c4 from Redneck Performance tha I am ging through. Already has a reverse manual VB with a TB and billit servo. I am ordering a propump and a 6 gear planet for it and a hardend input shaft. Still need to find a good kit to put in it as well as have someone build me a converter.whitefield wrote:X2 its a N/A cam and 100 shot is all I would want to blow through it . But again it will be fun and you can let us on the out side looking in know how it does.whatbumper wrote:I'm not saying its a bad cam don't get me wrong here. It probably is fine for NA application but it is not a nitrous cam especially on 104cl.stanggt wrote:we did degree the cam to the 104 cl that they told me to. I agree with the cam. I know there is more to be had with a bigger camshaft but will put some time on the motor with the one I have and then call bullit up and have them cut me a new one. If I could get about 700hp out of this motor with a cam swap then I may just forget the nos and have it all motor.whatbumper wrote:If tuned well I would guess between 650-675. If the cam events were right on then it may make more due to compression. It's definitely an all motor cam as is. I don't think it will take a 250 shot with that cam. Not very good cam timing events for a large dose like that.
Re: SBF stuff
[quote="whitefield"]Don't buy the pro pump ! Waist of money ! Use a c5 pump with a c6 pump bushing and get a planet set from jay at broader performance. Ptc or ucc converter . He has a good kit too![/quo where can I get one of those? Is this Jay guy a sponsor here? does he have everything im looking for the trans?
Re: SBF stuff
stanggt wrote:whitefield wrote:Don't buy the pro pump ! Waist of money ! Use a c5 pump with a c6 pump bushing and get a planet set from jay at broader performance. Ptc or ucc converter . He has a good kit too![/quo where can I get one of those? Is this Jay guy a sponsor here? does he have everything im looking for the trans?
Go to broader performance and yes he has everything you need . I run one of his trans brake vb and planet sets. Good guy !
Re: SBF stuff
thanks for all your help and input. Appreciate it.whitefield wrote:Go to broader performance and yes he has everything you need . I run one of his trans brake vb and planet sets. Good guy !stanggt wrote:whitefield wrote:Don't buy the pro pump ! Waist of money ! Use a c5 pump with a c6 pump bushing and get a planet set from jay at broader performance. Ptc or ucc converter . He has a good kit too![/quo where can I get one of those? Is this Jay guy a sponsor here? does he have everything im looking for the trans?
Re: SBF stuff
Time for the switch if you know what I mean.
Re: SBF stuff
[quote="whatbumper"]Time for the switch if you know what I mean. [/quot
Not !
Not !
Re: SBF stuff
Im fixing to go drag the bumper off this c4 equiped small lock car
at this no prep race in a few minutes..... Just sayin lol
Stock pump is good w a c6 bushing, dont waste money on a six pinion planet just get a rollerized 3 pinion.
Re: SBF stuff
I know but i just like to throw that out there when i can. Every trans is good for a certain combination and I guess I just know a lot about the sbf/c4 problems I use to have and no longer make that mistake at the 1000hp mark. Heck he may live up to his word and not ever spray it that hard and be satisfied with an all motor deal. It would et just fine and live just fine with the c4 then.
And my guy built that specific trans to begin with so I know what's in it and know the upgrades we are talking about here with it. These guys are right on with their ideas.
If it was mine i would anyway because i would end up changing cam and spraying the crap out of it within a year. Just seems like a waste to put $1200-$1300 in parts, labor, and new converter for this trans when a glide/converter package with bell for a sbf can be bought for $1900-$2100.
Great build, carry on!
Good luck tonight Jon.
Re: SBF stuff
bout wadded the thing up in the wall lol, was an impressive piece of drivin if i must say.........video to come.
Re: SBF stuff
Rut Ro......
Re: SBF stuff
I aint fixin it lol
Re: SBF stuff
builds character!richter69 wrote:I aint fixin it lol
Re: SBF stuff
might be time for the glide lol
» looking for 429/460 stuff
» BIG STUFF 3 ????
» Anyone been doing any car stuff?
» Delete
» Some new stuff
» BIG STUFF 3 ????
» Delete
» Some new stuff
Page 2 of 3
