pistons
pistons
can you run 429 pistons with football rods and 460 crank, there 429 2366 trw pistons scj copys ?
WVpuller87- Posts : 11
Re: pistons
I have read it was an old school trick, before forged 460 pistons where common. You have to machine the top off quite a bit for them to work with the longer stroke. Then you have to more than likely do something with the valve reliefs. Not really worth the trouble anymore.WVpuller87 wrote:can you run 429 pistons with football rods and 460 crank, there 429 2366 trw pistons scj copys ?
supervel45- Posts : 4498
Re: pistons
that's what I thought just wanted to double check with someone
Re: pistons
http://www.460ford.com/forum/showthread.php?t=150067 Check this look at Paul K's post at bottom.
Re: pistons
The piston would have to have .130 cut off of the top as the difference in stroke is .260. ( 3.85vs 3.59) . Since the piston is a dish design , there should be enough material to do that.
gt350hr- Posts : 662
Re: pistons
It seems like a pretty good trick for back in the day when 429CJ's SCJ's and PI's with forged pistons where plentiful along with 460 cranks. Like Paul said you can get zero deck height at around .1" without decking the block. It will also lighten the heavy TRW's. This was before everyone was spraying nitrous and the raised ring lands were not a problem, and forged pistons where $400.00 dollars in old money.
Re: pistons
Randy Malik has a pretty good deal on Autotec forged pistons.
» rotating ass. push rods msd pistons ''''c-460 pistons added to rotating assembly''''
» need pistons
» ? about my pistons
» 4.42 x 4.150 dome piston
» forged pistons
» need pistons
» forged pistons
