On head valve spring tester
What valve spring tester does everyone use to check seat pressures with the heads on?
Is there a tester that can be used with the girdle on the head?
thanks for any info.
460pulling- Posts : 249
Re: On head valve spring tester
I have a LSM on, but you need to remove the girdle
I like the LSM one. I figured I would have to remove the girdle.
Would a good process be to 1st remove the girdle 2nd test the springs. 3rd re-install the girdle 4th recheck the valve lash?
What are other good engine maintenance procedures?
thanks again.
thanks again.
I have the moroso valve spring tester and have used it for years and its still good, I also have a bench valve spring tester and the hand tester is still spot on.
butterbean- Posts : 676
I have the Moroso. It works fine but the LSM piece is better by far.
gt350hr- Posts : 662
LSM. works great.
whatbumper- Posts : 3024
460pulling wrote:I like the LSM one. I figured I would have to remove the girdle.
thanks again.
That's a good sequence, other things are leak down tests and cutting and inspecting oil filters.
thanks again.
We also do a lot of leak downs on motors and cut open all oil filters.
Ok thanks. I have an oil filter cutter and a leak down tester.
I ordered the lsm tester.
I even cut filters on my old jeep.
» Valve spring ?
» Scj head valve spring and retainers question
» Valve spring
» Affect of valve spring install height on spring rating..
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» Valve spring
