Scj head valve spring and retainers question
I'm sure this is a silly question for some but trying to get some bare SCJ head parts ordered/set up
With the solid cam I got from Randy
And I order crane 99954-16 springs, there are two retainers that come up that match the 1.460 outside diameter
#99954-16 and #99953-16, only difference is #54 adds 1.40 to the height and #53 adds 1.00 to height.
How do I know which ones to get? If installed at 1.825
Basically if I set these up to be like out of the box new
duff429- Posts : 202
Re: Scj head valve spring and retainers question
duff429 wrote:I'm sure this is a silly question for some but trying to get some bare SCJ head parts ordered/set up
At that height use the 99893-16 Crane springs;
99944-16 Retainers.
Or, better yet use the Ford Performance springs which came on the flat tappet SCJ heads ... M-6513-A351 springs and M-6514-A50 retainers.
It is all the same thing.
rmcomprandy wrote:duff429 wrote:I'm sure this is a silly question for some but trying to get some bare SCJ head parts ordered/set up
99944-16 Retainers.
Thank you sir, I had kinda a hard time finding the Ford racing stuff so I ordered the crane stuff
duff429 wrote:rmcomprandy wrote:duff429 wrote:I'm sure this is a silly question for some but trying to get some bare SCJ head parts ordered/set up
99944-16 Retainers.
Those heads came from FRPP with correct spring cups, PC type seals and machined locks, also.
rmcomprandy wrote:duff429 wrote:rmcomprandy wrote:duff429 wrote:I'm sure this is a silly question for some but trying to get some bare SCJ head parts ordered/set up
99944-16 Retainers.
These heads are new, but the guy went another route, and have valves and guides. Il have to see when I get back home if they have the spring cups,and seals. I might have to order some of that from you.
» On head valve spring tester
» Head on valve spring compressor
» Valve Spring Retainer Question.
» Quick valve spring question
» Spring retainers
» Spring retainers
