Head on valve spring compressor
+7
QtrWarrior
whitefield
11 posters
Head on valve spring compressor Empty Head on valve spring compressor
Post  Doug Rahn February 17th 2017, 6:07 pm
Anyone have a recommendation for a good compressor to use with the heads on? I would love to have a Buxton, but can't justify the expense at this time.
Head on valve spring compressor Empty Re: Head on valve spring compressor
Post  whitefield February 17th 2017, 6:27 pm
http://www.lsmproducts.com/ Best bang for the buck!
whitefield
whitefield
Post  Curt February 17th 2017, 7:39 pm
LSM. I have both but the Buxton is hard to beat.
Post  maverick February 17th 2017, 7:43 pm
I made mine.
Post  QtrWarrior February 17th 2017, 9:26 pm
Doug.. I have one.... Cool
QtrWarrior
QtrWarrior
Post  cool40 February 17th 2017, 11:14 pm
maverick wrote:I made mine.
x2 ! I have used LSM with good results. I found most tools for shaft setups were different to mine. Shocked
Post  Doug Rahn February 18th 2017, 8:03 am
QtrWarrior wrote:Doug.. I have one.... Cool
Thanks for the offer Mike, but it's a tool I should have added to my collection a long time ago.
Post  jbozzelle February 18th 2017, 12:06 pm
I have a Moroso that works well
Post  rmcomprandy February 18th 2017, 12:27 pm
Stud mounted, Bolt down rockers and Shaft type rockers usually will require a different valve spring removing tool.
Post  cool40 February 18th 2017, 1:58 pm
rmcomprandy wrote:Stud mounted, Bolt down rockers and Shaft type rockers usually will require a different valve spring removing tool.
that's where I ran into trouble,with shafts anyway. Different size and width of bolt pattern on them so one needs to be sure of what they have. Stud type are mostly universal.
Head on valve spring compressor Empty LSM
Post  HorsinAround February 20th 2017, 12:47 pm
Doug,
The LSM stuff is the sh.t!
http://www.lsmproducts.com/lsm_products/valve_spring_compressors
Its what I have used for years.
http://www.frontpagefab.com
Post  10.0 February 21st 2017, 4:20 am
Yeah, that Buxton onhead spring compressor takes all the work out of 400 lbs closed pressure springs.
Makes the job almost fun!
10.0
Post  HorsinAround February 21st 2017, 9:23 am
10.0 wrote:Yeah, that Buxton onhead spring compressor takes all the work out of 400 lbs closed pressure springs.
It looks like an awesome piece, but dang, you would have to use it quite often to justify the cost.
Post  AZFairlane February 21st 2017, 9:36 pm
I thought LSM tools were expensive, but they're really proud of that Buxton part. Shocked
AZFairlane
AZFairlane
