Drag trucks
+9
dirt_worker
514F-1
83-88T-Bird Guy
chuck
13 posters
Drag trucks
I have a new project, putting a 557 in a gen 1 lighting. Never set a truck up, any advise on good suspension parts. It is a ladder bar rear.
chuck- Posts : 414
Re: Drag trucks
Copperhead would be the guy to talk too.
Re: Drag trucks
I put a 4 link under my Ranger so can't give any info on the ladder bar
Re: Drag trucks
bbf-falcon wrote:Copperhead would be the guy to talk too.
^^ This.
Keith is the man to talk to.
83-88T-Bird Guy- Posts : 1003
Re: Drag trucks
Biggest problem with trucks in drag racing is weight transfer. No matter what you do, you will never get real close to 50/50, they are all nose heavy. Good shock and springs in the front will help it transfer weight better..also, some weight in the bed can also help. M y truck is tube chassis, but it still is 60/40 nose heavy.
514F-1- Posts : 242
Re: Drag trucks
The 514 Ranger was 58/42. Ladder bars, and transferred well. Wheels way up on launch....downtrack, not so good.
maverick- BBF CONTRIBUTOR
Re: Drag trucks
Too many people "assume" pickups are hadicapped by poor weight bias.
Ive heard it all...and frankly my experience says its not an issue at all.
My 3800 lb all steel f100 is getting low 1.40 60fts on leafsprings and 275 dragradials. Run 6.30s w a57% nose weight.
dirt_worker- Posts : 535
Re: Drag trucks
Heck my Mustang is 59.5/40.5!
BigBlockRanger- Posts : 1267
Re: Drag trucks
All input welcome. What's a good shock spring package,ie
chuck- Posts : 414
Re: Drag trucks
Where did all of the pro stock Rangers go?
Curt- Posts : 2791
Re: Drag trucks
Awesome truck. The weight bias isn't really a handicap once you get it set up. One thing that we have found is that, once you have a truck setup, so that it will transfer weight, is that... When you get weight transfer, there is a lot of it...which is a good thing.
dirt_worker wrote:Too many people "assume" pickups are hadicapped by poor weight bias.
514F-1- Posts : 242
Re: Drag trucks
Curt wrote:Where did all of the pro stock Rangers go?
To Top Sportsman and the Super classes?
Re: Drag trucks
Like James has posted...fox bodys are heavier on the front percentage than alot of pickups and nobodys complaining about how poorly they work
Point being theres just alot more too it than just weight bias....
Re: Drag trucks
Our really quick radial cars are well over 57-58%. Ladder bar, cal trac, 4 link all work
whatbumper- Posts : 3024
Re: Drag trucks
chuck wrote:I have a new project, putting a 557 in a gen 1 lighting. Never set a truck up, any advise on good suspension parts. It is a ladder bar rear.
1.31,.....60'
5.89 (1/8th) / 9.33 (1/4)
Rear Suspension
36" S&W Ladder Bars,.... http://www.swracecars.com/store/LADDER-BARS-36-DOUBLE-ADJUSTABLE-WITH-MOLY-ROD-ENDS-OSCARItem_20=40-107.aspx
w/ POS Shock kit,..... http://www.swracecars.com/store/ProSeries-Shock--Spring-Kit-with--Springs--adjustable-rear-housing-brackets-OSCARItem_23=40-223-XXX.aspx
FWIW,...... I'm changing the Shocks over to a REAL set of Coil-Overs,.....because I'm WAY past their limit with my new engine.
Front suspension -
AJE set-up that replaces EVERYTHING up front.
It comes complete with K-Member, Aerospace or Willwood brakes & coil-over strut assy's.
It's NOT cheap. Around 4k
Not listed on their website,....... but they've built a couple of dozen kits. Call them,....and they'll know what you're talking about.
Copperhead- Posts : 492
Re: Drag trucks
My truck is 52% front/48 rear. I don't know how it's going to work yet as it always breaks before I can even get down the track, lol. I fear it may not have enough weight on the front.
Re: Drag trucks
Too much HP, might have to put a camero in the box
FalconEh- Posts : 1448
» F150 drag trucks and enclosed trailers
» Towing topic - new trucks vs older trucks ratings opinions looking at new trucks
» Picked up a 1977 F350 hauler
» Beware of Ford Trucks
» Superduty death wobble
