valve caps for more lift
460pulling
dcbigblock67
Just want to play around to see if the 460 engine would like more cam' would putting on the caps give more lift? Cam is a .563-583 crane cam ...seems like the car runs out of breath on the big end.seems lines cheap experiment..
dcbigblock67- Posts : 10
Re: valve caps for more lift
The only way that i know of to get more lift would be to change the rockers from 1.73 to 1.8 or get a new camshaft. Adding height to the valve tip will only make your adjustment higher and most likely require longer pushrods for the correct geometry. If you added the Lash cap and kept the same rocker placement the valve would never close all the way. I am not and expert but I'm sure if I am wrong someone will correct me.
460pulling- Posts : 249
tight the lash up ,close it down to .012" and make a pass . you'll be using some of the clearancing ramp on the cam for more lift . it with also give you more duration
Frank Merkl- Posts : 1524
So instead of .026 hot try.012 hot lash?
simple answer, yep
kjett- Posts : 1169
Frank Merkl wrote:tight the lash up ,close it down to .012" and make a pass . you'll be using some of the clearancing ramp on the cam for more lift . it with also give you more duration
+1 If changing the lash makes a noticable difference ( positive or negative) it will let you know if it's the right direction or not. My guess is it will be positive
gt350hr- Posts : 662
lash cap/valve cap will not on its own give more lift. (own its own) depends on rocker geomtry, be the same as changing push rod length.
a lash change of several thousands would have little effect but can make a good different in power.
I'd try one valve at a time, exh. first,, then int. w/ex back to std. the both.
DanH- Posts : 1081
» Valve lift?
» how much valve lift on stock springs?
» Minimum valve to valve clearance
» Will Miller mid lift rockers 1.8 be good for a solid roller 272 Dur. .688 lift?
» How much does it cost to get 4bolt caps get put on?(roughly) and what can my 77 460 block with center 4bolt caps block handle?
