Anyone using rail rockers?
Super Snake Steve
tpndrcn
Anyone using rail rockers? Empty Anyone using rail rockers?
Post  tpndrcn May 21st 2015, 7:39 pm
Is anyone still using factory 68',69' rail rockers with an aftermarket hydraulic flat tappet cam? What is safe lift? I know that stamped steel or rollers are better, but I was trying to avoid spending the money and wanted other opinions.
tpndrcn
Anyone using rail rockers? Empty Re: Anyone using rail rockers?
Post  maverick May 21st 2015, 7:59 pm
Spend the money. Scorpions are a fair piece for a fair price. Take the rails to a swap meet.
Post  tpndrcn May 21st 2015, 8:45 pm
I agree the rockers are reasonable but it's the $105 to mill the pedestal down where the stud goes in, then buying studs,and guide plates too
tpndrcn
Post  maverick May 21st 2015, 9:05 pm
How much hotrod are you trying to make? You can run the rail deals if this is a stock type cruiser deal with a small hyd. cam, but if you plan to flog it....well, you know. If it was me, I'd scrape up a few extra bucks, sell a few parts, skip a couple of happy meals and hit the swap meet. I just don't have much use for a stock rail rocker.
Post  tpndrcn May 21st 2015, 10:37 pm
I know I should just bite the bullet because I want a strong running street/strip car.
tpndrcn
Post  Super Snake Steve May 21st 2015, 10:56 pm
Ford got rid of the rail for a reason and you should to just 2 cents worth naw make that 1 cents worth
Super Snake Steve
Post  supervel45 May 22nd 2015, 9:05 am
https://www.429-460.com/t13913-dove-c-heads If you don't want to spend alot of money, stay conservative with your cam choice.
Post  tpndrcn May 22nd 2015, 9:56 am
Supervel45 that was a great article to help me. I really am thinking hard on just doing the rockers now, rather than have to take the heads off later. Have you heard of Angus gold rockers, they are a good price but I wonder how well they work on bbf's?
tpndrcn
Post  supervel45 May 22nd 2015, 10:35 am
Never heard of Angus. This is the way I see it, you need to stay with a mild build or spend the money to do it right if you are seriously wanting to go HiPerformance. This would include Porting, Large SS valves, hardened seats, cut valve guides for larger than .550" lift cam, new springs/retainers, locks, hardened pushrods, guideplates, and name brand quality roller rockers. If you do spend the money to cut the guide bosses, go ahead and cut the valve guides to, so that you can run a higher lift cam. If you go with a bigger cam you will still need the new springs retainers and locks, along with hardened pushrods. Keep this in mind, a bigger cam will not help HP if the heads don't flow well.
Post  supervel45 May 22nd 2015, 11:25 am
tpndrcn wrote:Is anyone still using factory 68',69' rail rockers with an aftermarket hydraulic flat tappet cam? What is safe lift? I know that stamped steel or rollers are better, but I was trying to avoid spending the money and wanted other opinions.
http://www.ebay.com/itm/COMP-CAMS-BBF-429-460-cid-FORD-34-244-4-268-276-535-535-LSA110-0-/381268475347?hash=item58c55f3dd3&vxp=mtr Ran across this cam. Should work good for a mild build with rail rockers with stock heads.
Post  supervel45 May 22nd 2015, 11:26 am
Double post.
Post  tpndrcn May 23rd 2015, 8:38 am
Supervel45. I am not wanting to go with a extremely high lift cam just because I street drive this 80% , and it sees track duty 20%. I went ahead and bought the Angus gold 1.73 rockers, gonna get the guides and pedestals milled, and run a mild cam. I ran 13.40s with the small block and I would just like to achieve that or better with the bb setup. Thanks for the link
tpndrcn
Post  rmcomprandy May 23rd 2015, 12:06 pm
tpndrcn wrote:Supervel45. I am not wanting to go with a extremely high lift cam just because I street drive this 80% , and it sees track duty 20%. I went ahead and bought the Angus gold 1.73 rockers, gonna get the guides and pedestals milled, and run a mild cam. I ran 13.40s with the small block and I would just like to achieve that or better with the bb setup. Thanks for the link
If you are going to do all that, then it is my opinion that you should have gone to a solid lifter, also.
However, you might not actually use the extended RPM range a solid lifter would afford you. In that case a hydraulic will probably be adequate.
Post  FalconEh May 23rd 2015, 7:59 pm
tpndrcn wrote:I know I should just bite the bullet because I want a strong running street/strip car.
^^^^^^^This, a good solid lifter is great for the street/strip package, just keep in mind your gear - trans/converter - weight combination when choosing or specifying.
Post  maverick May 23rd 2015, 8:16 pm
Back to original topic, I was tossing rail rockers on the scrap pile in 1968. While they may work oK for their intended purpose, I'm sure they haven't climbed higher on the rocker arm totem pole since then. The "street/strip" use definitely rules 'em out, IMO.
Post  FalconEh May 23rd 2015, 9:53 pm
maverick wrote:Back to original topic,  I was tossing rail rockers on the scrap pile in 1968.  While they may work oK for their intended purpose, I'm sure they haven't climbed higher on the rocker arm totem pole since then.  The "street/strip" use definitely rules 'em out, IMO.
He already bought them ^^^^ Rolling Eyes
Post  maverick May 23rd 2015, 10:00 pm
Noted. Just adding a nail to the rail rocker coffin. Laughing
Post  tpndrcn May 23rd 2015, 10:23 pm
Well it was just an idea because the whole budget idea was laid out like this, I sold my sbf and trans for $2400. So to keep my wife happy I agreed to not spend more than that to go back to bb setup.Which includes eng.,trans,converter, headers,carb,intake,exhaust,and a the little etc.. stuff. I have a great job and make good money but it came to priority of my family of six (my wife and I and 4 kids) and spending like crazy like I did when I was in highschool. So I was trying to cut some corners to be able to just get my hotrod going again with the bb setup, then upgrade in due time.So that's why I was trying to use some stock stuff.
tpndrcn
Post  dfree383 May 23rd 2015, 11:30 pm
You can use them but keep the cam real mild and don't try and use heavy springs.
Post  maverick May 24th 2015, 8:36 am
tpndrcn wrote:Well it was just an idea because the whole budget idea was laid out like this, I sold my sbf and trans for $2400. So to keep my wife happy I agreed to not spend more than that to go back to bb setup.Which includes eng.,trans,converter, headers,carb,intake,exhaust,and a the little etc.. stuff. I have a great job and make good money but it came to priority of my family of six (my wife and I and 4 kids) and spending like crazy like I did when I was in highschool. So I was trying to cut some corners to be able to just get my hotrod going again with the bb setup, then upgrade in due time.So that's why I was trying to use some stock stuff.
Yup. That's hotrodding ain't it? From time to time we all struggle to justify the money we spend on our toys...a bunch of poor guys with a rich man's hobby. I'm not taking shots at your parts choices or budget, but I felt that occasionally flogging rail rockers on a dragstrip was an invitation to heartbreak. Just looking out for you, man. Cheers to you.cheers
