lenco throwout bearing
Ive got a mcleod bell with a fork in it and mcleod 2 disc clutch need to figure out what throwout bearing to use its a 1-3/8 x10 spline the outer diameter of the candle stick is 1.765 anybody have any recommendations
fordmonsta- Posts : 236
Re: lenco throwout bearing
Maybe this? http://www.jerrybickel.com/bellhousing-flexplate-and-clutch-components/cross-shaft-throw-out-bearings---jbrc5742.html
bigblock t-bird- Posts : 201
Need more info on you setup. Got any pics. Steve
http://www.rjracecars.com/Bellhousing-Prodlist.html
I ended up calling lenco this morning and the guy that answered the phone was kind of a dick on the phone and referred me to bickel they got me lined out with what I needed to know only thing I didnt find out is how much clearance is supposed to be btween the clutch fingers and the throwout bearing face im running a mcleod 2 disc clutch and mcleod blowproof bellhousing
You need .250 from clutch fingers to release bearing face. With the release bearing all the way back and all the slack in the fingers back as well. You may need to install a return spring on it. Are you running a fork? Steve
Yra im running a fork it loks like a homemade deal this trans and stuff supposedly came out of an 80s thunderbird ihra prostock this is my first adventure into a car with an adjustable type clutch im ready to get it going
» KING MAIN BEARING CLEARANCE'S AT PARTING LINE..?
» #2 rod bearing
» Cam bearing help!!!
» One way clutch bearing
» Bearing Issue
» #2 rod bearing
» Bearing Issue
