What kills a stock rod
butterbean
away
85bigblockfox
What kills a stock rod Empty What kills a stock rod
Post  85bigblockfox July 15th 2015, 8:48 am
For instance if you have a 900gram piston on the end of a stock rod that has had the stress riser taken off with good bolts what would a safe bet to say cylinder pressure or rpm?
85bigblockfox
85bigblockfox
What kills a stock rod Empty Re: What kills a stock rod
Post  dfree383 July 15th 2015, 8:51 am
RPM and heavy Pistons. It's simple math.
proprer machine work can midi gate it to a point, but the simple math is going to slap you in the face sooner or later.
Post  85bigblockfox July 15th 2015, 8:55 am
dfree383 wrote:RPM and heavy Pistons. It's simple math.
I know Im riding a fine line but Im going to put a plate on my car with a small 100 or so. I have ran this engine for 5 years and it goes to 7k every pass. Im hoping to pick up some et and lower the rpm if that makes sense.
85bigblockfox
85bigblockfox
Post  rmcomprandy July 15th 2015, 9:11 am
A production big block Ford rod, reciprocating at that average of 75 feet per second, won't last long with a 900 gram piston and pin before it breaks in the beam.
The rod will probably get a slight bend just under the pin end first.
Post  away July 15th 2015, 9:28 am
^^^^^^^Please give link or explain the math associated with this. I would like to see where my combos are at. What is the high number vs RPM to avoid? etc......
Thanks in advance
away
away
Post  85bigblockfox July 15th 2015, 9:37 am
rmcomprandy wrote:A production big block Ford rod, reciprocating at that average of 75 feet per second, won't last long with a 900 gram piston and pin before it breaks in the beam.
The rpm is more of a key player in one letting go then cylinder pressure?
85bigblockfox
85bigblockfox
Post  rmcomprandy July 15th 2015, 9:43 am
YES ... The compressive strength is much higher than the tensile strength.
Post  rmcomprandy July 15th 2015, 9:52 am
away wrote:^^^^^^^Please give link or explain the math associated with this.  I would like to see where my combos are at.  What is the high number vs RPM to avoid?  etc......
Thanks in advance
When Ford Racing originally released their 514 crate engine, it had NEW production marine rods with a bushed pin end. The red-line was 6,200 RPM, (just under 75 feet per second with that 4.300" stroke).
After almost  a 100 warranty claims from broken rods, (all broken in the beam), they went to using an Eagle H-beam rod and the problems almost totally disappeared.
Post  85bigblockfox July 15th 2015, 10:02 am
Thanks for the advice. My pistons are 2443 trw with dove heads. I know the compression is on the high side but if I lower the rpm, you think the rods will stay happy with added pressure of nitrous? Only spraying a 100.
85bigblockfox
85bigblockfox
Post  85bigblockfox July 15th 2015, 10:03 am
Thanks in advance
Would you happen to have the formula for figuring rod speed?
85bigblockfox
85bigblockfox
Post  dfree383 July 15th 2015, 10:20 am
Piston Speed
Cm = .166 x L x N
Cm is mean piston speed, in feet per minute
L is stroke, in inches
N is crankshaft speed, in RPM
That get you FPM / by 60 for FPS
Post  85bigblockfox July 15th 2015, 11:09 am
dfree383 wrote:Piston Speed
Cm = .166 x L x N
Thanks. So anything under 75 fps is a safe area?
85bigblockfox
85bigblockfox
Post  butterbean July 15th 2015, 11:45 am
85Bigblockfox, if it were me I would take it apart and change the rods, It sounds like you have a good combo and it runs well, so why take a chance on breaking a rod and destroying your engine when you can put a set of rods in it for a little money and your time, and you could do a freshen up on it while you are in there, JM2C!!!!!!
butterbean
butterbean
Post  gt350hr July 15th 2015, 11:52 am
Thanks in advance
Randy,
Much of this was due to AER installing ARP wave lock rod bolts. These "move" material around the bolt hole in the rod and IF ( as was the case) the cap isn't chamferred enough to compensate , the cap will not seat properly ( as I think you already told me). My 521 has a set of those rods and my "rod guy" reworked them the way you told me to , and I am using them. I will NOT be running my 521 over 4,500 rpm in my race car hauler.
gt350hr
Post  85bigblockfox July 15th 2015, 11:56 am
butterbean wrote:85Bigblockfox, if it were me I would take it apart and change the rods, It sounds like you have a good combo and it runs well, so why take a chance on breaking a rod and destroying your engine when you can put a set of rods in it for a little money and your time, and you could do a freshen up on it while you are in there, JM2C!!!!!!
I have a set of h beams on the shelf. Engine is going in a lighter car in the winter and only have 1 more race this year. Plan is to spray 100 to it max. Car is heavy at 3400lbs been 10.91@123. Trying to get a 10.50 out of it before I swap cars.
85bigblockfox
85bigblockfox
Post  gt350hr July 15th 2015, 12:03 pm
Here is the rod killer equation. Piston weight squares for every 1,000 rpm increase.
gt350hr
Post  kim July 15th 2015, 4:27 pm
Cm = .166 x L x N
Life expectancy of oliver rods, 620 gram pistons and 90fps?
kim
Post  DaveMcLain July 15th 2015, 4:38 pm
gt350hr wrote:       Here is the rod killer equation. Piston weight squares for every 1,000 rpm increase.
NO, the loading goes up geometrically so that every time you double the rpm the loading goes up 4X.
DaveMcLain
Post  gt350hr July 15th 2015, 6:05 pm
guess I went to a different school.
gt350hr
Post  kim July 15th 2015, 6:19 pm
CA..... ya know, where everyone should do whatever they feel. Engineer, plastic surgeon, movie star............. pay your fee get your B,
kim
Post  rmcomprandy July 15th 2015, 7:07 pm
gt350hr wrote:
Thanks in advance
        Randy,
That was a problem in the beginning and had a lot to do with spun bearings and subsequent heat causing the rod to break at the big end ... it had nothing to do with the strength of the production marine rod or why the change to the Eagle rods, happened.
By the way, it was only at the beginning of that crate motor offering and it was less than 100 rods which didn't get a champher under the ARP rod bolt head; NOT the cap.  No champher was on the cap faces either but, that was not the cause of any breakage problems.The mistakes were caught after those. That happening was for about 19 engines, (which got one or more of those rods), and they sold hundreds of those original crate motors afterward.
Post  quick 52 July 15th 2015, 8:46 pm
I'm running stock rods... My combo is stock crank, rods and KB piston cast. truck #3870 with driver spray 125hp best ET 10.71 @ 126mph 6800 rpms...
quick 52
Post  dfree383 July 15th 2015, 10:16 pm
Cm = .166 x L x N
What stroke and rpm?
Another issue with the stock rods is the big ends deform and spin the bearings.
Post  kim July 16th 2015, 12:06 am
3.9 stroke 9600 rpm.
kim
Post  dfree383 July 16th 2015, 7:27 am
kim wrote:3.9 stroke 9600 rpm.
your looking at a weird application..... They will outlast your valve train.....
