1978 f150 4x4 302 swap
1978 f150 4x4 302 swap Empty 1978 f150 4x4 302 swap
Post  phil1206 July 26th 2015, 10:38 pm
my brother bought a 1978 f150 4x4 has a 351m he's wanting to put a 302 in it. my question is do we need to find other frame horns or jut move the holes in the ones he has?
phil1206
1978 f150 4x4 302 swap Empty Re: 1978 f150 4x4 302 swap
Post  whitefield July 27th 2015, 8:16 am
phil1206 wrote:my brother bought a 1978 f150 4x4 has a 351m he's wanting to put a 302 in it. my question is do we need to find other frame horns or jut move the holes in the ones he has?
If it had a 351m/400 in it you don't have to move the frame horns . Just get 78 two wheel drive truck mounts and the correct transmission { small block C6} and put her in ! Wink equal length fox mustang headers work or the shorties too !
whitefield
whitefield
Post  phil1206 July 29th 2015, 11:27 am
its a 4 speed truck. dose a twd have the same style horns or are they a strap style.
phil1206
Post  whitefield July 29th 2015, 7:11 pm
phil1206 wrote:its a 4 speed truck. dose a twd have the same style horns or are they a strap style.
Then make sure you have the small block bell housing and flywheel. Frame horns are different from 2 wheel drive to four wheel drive but the mount that bolts to the blocks have the same stud that goes thru the stands or frame horn on two and four wheel drives.
P.s a true 460 truck engine stands and mounts a different .
whitefield
whitefield
