New 460 build
New 460 build Empty New 460 build
Post  Tnipp August 3rd 2015, 9:33 pm
I'm building a stock long block 460 with a Victor intake , stock plus cam shaft, headers and A Quick fuel carburetor curious on how much horsepower that would be
Tnipp
New 460 build Empty Re: New 460 build
Post  supervel45 August 3rd 2015, 9:41 pm
Need more info, like year engine, heads, cam specs. ect. before anyone can give an answer.
Post  Tnipp August 3rd 2015, 9:50 pm
1990 engine stock heads and small aftermarket camshaft not sure on sprin not sure on specs
Tnipp
Post  supervel45 August 3rd 2015, 10:10 pm
I would not use a Victor intake. I believe the 1990 heads have small intake valves also. If you gain 50HP over stock I think you would be doing good from what you describe.
Post  Tnipp August 3rd 2015, 10:12 pm
Ok thinks
Tnipp
Post  butterbean August 3rd 2015, 10:28 pm
the victor intake will make less HP on a stock type engine, you need a eddy performer for your combo, good luck
butterbean
butterbean
Post  rmcomprandy August 4th 2015, 9:35 am
The intake ports at the flange will not be aligned with those heads to a carburetor intake manifold without some kind of adapter being used..
Price Motorsports has those.
Post  Tnipp August 4th 2015, 10:25 am
Was using this motor for a mock up for more horsepower motor I didn't want to buy two intakes but it looks like I'm going to have to appreciate the info
Tnipp
