Dove heads valve size
Dove heads valve size Empty Dove heads valve size
Post  mudtrucker November 25th 2009, 9:27 am
Are 2.224/1.75 valves to big for dove heads? The motor they will be going on is a very high compression 460, which leads to my next question. What pistons are available that would give me 14-15:1 compression in a dove headed 460?
Thanks Bob
mudtrucker
mudtrucker
Dove heads valve size Empty Re: Dove heads valve size
Post  lghting94 November 25th 2009, 9:30 am
on the valve size I cant honestly answer that question but on the pistons to get that compression i think your gonna have to go custom.
lghting94
lghting94
Post  rmcomprandy November 25th 2009, 12:53 pm
Any combination of valve head diameter sizes equalling 4" or less will fit.
Post  longroofracer November 26th 2009, 3:40 am
mudtrucker wrote:Are 2.224/1.75 valves to big for dove heads? The motor they will be going on is a very high compression 460, which leads to my next question. What pistons are available that would give me 14-15:1 compression in a dove headed 460?
Thanks Bob
If Carl still has these... they will be close to 14:1 1 set: +10cc dome tops, +.080, OEM reliefs, 1.770CH
https://www.429-460.com/stuff-for-sale-f1/diamond-piston-clearance-t1242.htm
longroofracer
longroofracer
Post  t120r November 26th 2009, 12:27 pm
I have a set of JE 0.060" over domed 460 pistons with pins and locks. Tops are polished already. These would give you the compression that's for sure. Send me a PM and we can talk if you're interested.
t120r
