What's the hot clutch set-up
What's the hot clutch set-up Empty What's the hot clutch set-up
Post  dfree383 August 20th 2015, 10:10 am
For stock eliminator racing?
5.0 5 speed
What's the hot clutch set-up Empty Re: What's the hot clutch set-up
Post  gmsmkr August 20th 2015, 5:05 pm
RST CLUTCH from mcleod is what we used now it wasn't a stock elem car but was a damn good set up and did not need a special Flywheel
Horsepower Rating 800
Pressure Plate Style Diaphragm
Flywheel No
Spline 1 1/16" x 10
Clutch Patterns 10" & 10.5" Long & 10" Diaphragm
gmsmkr
gmsmkr
Post  dfree383 August 21st 2015, 8:31 pm
gmsmkr wrote:RST CLUTCH from mcleod is what we used now it wasn't a stock elem car but was a damn good set up and did not need a special Flywheel
Flywheel No
Spline 1 1/16" x 10
Can't use a twin disk per rules...... Any other alternatives other than the soft lok?
Post  whitefield August 21st 2015, 9:02 pm
Act or SPEC .
whitefield
whitefield
Post  FalconEh August 21st 2015, 10:08 pm
no rechargeable only disposable Smile
Post  gmsmkr August 21st 2015, 11:09 pm
I would give SPEC a call they can set you up for sure just make sure you tell them you want a sprung center or your left calf will be alot bigger then your right Razz
gmsmkr
gmsmkr
