Custom oil pan
Page 2 of 2 Previous  1, 2
Custom oil pan - Page 2 Empty Re: Custom oil pan
Post  dfree383 September 3rd 2015, 2:29 pm
A pickup tube is welded to the oil sump with a an adaptor on it, then a hose goes to the inlet side of the pump.
From the pump you use another floes to go to an adaptor/inlet located at the oil filter boss on the side of the block, then it follows the same path thru the oil filter into the engine as normal with the internal pump.
Post  JigSawMan September 3rd 2015, 2:55 pm
dfree383 wrote:A pickup tube is welded to the oil sump with a an adaptor on it, then a hose goes to the inlet side of the pump.
Ok thanks for the description.
JSM
JigSawMan
