Morel's, what size groove is needed
Daytonatunnel
Morel's, what size groove is needed Empty Morel's, what size groove is needed
Post  Daytonatunnel August 30th 2015, 10:26 am
Was there any good guess as to what size groove is needed to "fix" the upper end oiling problem ?
Daytonatunnel
Daytonatunnel
Morel's, what size groove is needed Empty Re: Morel's, what size groove is needed
Post  cool40 August 30th 2015, 11:58 am
It's best to do a trial run,IMO. Remember hot oil moves faster than cold also so don't get carried away.
Post  Daytonatunnel August 30th 2015, 1:55 pm
I hear that, just thought someone would have a baseline starting point. I want to have my buddy mill it, so they all will be the same.
Daytonatunnel
Daytonatunnel
Post  dfree383 August 30th 2015, 2:17 pm
Lem may have an idea.
Post  rmcomprandy August 30th 2015, 2:32 pm
Daytonatunnel wrote:Was there any good guess as to what size groove is needed to "fix" the upper end oiling problem ?
About a .002" flat is all; just run a mill file across that part.
Post  Daytonatunnel August 30th 2015, 5:33 pm
THANKS !!!!!!!!!
Daytonatunnel
Daytonatunnel
Post  DaveMcLain August 30th 2015, 7:22 pm
Yes, if they don't oil enough I just polish down the area right around the hole about .001 measuring with a mic using a cratex wheel. A little at a time and a little is usually all they need.
DaveMcLain
Post  supervel45 August 30th 2015, 8:16 pm
cool40 wrote:It's best to do a trial run,IMO. Remember hot oil moves faster than cold also so don't get carried  away.
This makes a lot of sense. Tolerance stack comes to mind for some reason also.
Post  DaveMcLain September 1st 2015, 7:16 pm
Every situation tends to be different. I have a small block Ford out there in a road racing application with a Dart block, unmodified Morel lifters fed by a .075 hole for the entire valvetrain. The Bozo who built it at Roush honed the lifter bores too much and they were way too loose with the Comp lifters that were in it so I switched to the morels. It originally had a .125 restriction hole feeding the valvetrain which was making it flood the valve covers and blow out oil. I go for about 1 drip from the rocker every second or so turning the pump by hand with cold oil.
DaveMcLain
Post  Notch 501 September 16th 2015, 3:19 pm
dont groove to much it will fill your vave covers with oil ,coming out of the water box Evil or Very Mad
Notch 501
Notch 501
