460 "multi groove" pulleys
mitch
SLOWnSTEADY
460 "multi groove" pulleys Empty 460 "multi groove" pulleys
Post  SLOWnSTEADY August 5th 2010, 1:32 pm
Looking at doing a "multi groove" pulley setup on my 460 fox. I am keeping my power steering in this one!
I am wondering if anyone has a nice write up on doing this? I have searched and found that you can use SBF pulleys by enlarging the center bore on the pulleys and re drill the water pump pulley bolt pattern. I have also seen people just use the 460 truck pulleys from early 90's F350 with a 460.
I was thinking of going that route myself, the F350 pulleys...
SLOWnSTEADY
460 "multi groove" pulleys Empty Re: 460 "multi groove" pulleys
Post  SLOWnSTEADY August 7th 2010, 8:46 am
BUMP!
SLOWnSTEADY
Post  SLOWnSTEADY August 9th 2010, 6:55 pm
C'mon... I thought this was the "king shit, BBF website"? I know some of you have to be running a similar setup?
SLOWnSTEADY
Post  Lem Evans August 9th 2010, 7:04 pm
What I know about this is not much but I'd think you are correct....gotta have the late model truck pulleys...the older stuff was all V groove. I assume you have a damper with stock pattern and spacing.
Post  SLOWnSTEADY August 9th 2010, 7:09 pm
Lem Evans wrote:What I know about this is not much but I'd think you are correct....gotta have the late model truck pulleys...the older stuff was all V groove. I assume you have a damper with stock pattern and spacing.
damper is stock from a '76 Thunderbird as of right now. I will be getting an SFI pretty soon though.
SLOWnSTEADY
Post  Lem Evans August 9th 2010, 7:11 pm
The bolt pattern should be cool then.
Post  mitch August 9th 2010, 8:31 pm
I have a crank and water pump pulley from my '97 F350, you can have them for little more than the cost of shipping if you want to try try them. I can take pics of the engine too if that could help figure out if the stuff will fit.
mitch
Post  SLOWnSTEADY August 9th 2010, 9:22 pm
mitch wrote:I have a crank and water pump pulley from my '97 F350, you can have them for little more than the cost of shipping if you want to try try them. I can take pics of the engine too if that could help figure out if the stuff will fit.
Those are actually the two pulleys I still need. shoot me some pictures and a price, they should both easily fit in a USPS flat rate box...
SLOWnSTEADY
Post  mitch August 10th 2010, 9:44 am
460 "multi groove" pulleys Qpp81t
460 "multi groove" pulleys 2vdlh5e
460 "multi groove" pulleys 34y4ign
460 "multi groove" pulleys Fnv8lw
You can have them for $20 shipped.
Troyer Performance makes under drive pulleys for the 460 trucks. The set includes crank, water pump and alternator pulleys for $160. They might be a good option for you. I have a set on my truck and am happy with them.
http://www.troyerperformance.com/cgi-bin/ppistore.pl?user_action=detail&catalogno=520511
mitch
Post  SLOWnSTEADY August 10th 2010, 10:02 am
mitch wrote:460 "multi groove" pulleys Qpp81t
for $20 shipped, I will give them a try. Pm me your paypal address.
SLOWnSTEADY
Post  SLOWnSTEADY August 10th 2010, 11:24 am
payment sent
SLOWnSTEADY
Post  mitch August 10th 2010, 1:37 pm
got them shipped. Let us know how they fit on your mustang.
mitch
Post  89lxcoupe August 11th 2010, 1:27 pm
i'm using the same pulleys !
460 "multi groove" pulleys IMG_0846
460 "multi groove" pulleys IMG_0855
460 "multi groove" pulleys IMG_0873
89lxcoupe
Post  SLOWnSTEADY August 11th 2010, 2:52 pm
89lxcoupe wrote:i'm using the same pulleys !
Nice, except that MASSIVE power steering bracket LOL. Same setup I am going with but I will be making my own brackets like I did on my SBF I put in the RX7. Well, I just copied March brackets and it ended up costing me like $20 to get them both made so...
SLOWnSTEADY
Post  the Coug August 11th 2010, 3:14 pm
See if Pro Comp has stole it and started making one yet..... Shocked
Post  89lxcoupe August 11th 2010, 3:22 pm
i kinda like the factory look, but if i could find a single ps bracket that would line up with my multi groove pulleys i would switch.
89lxcoupe
Post  SLOWnSTEADY August 11th 2010, 6:10 pm
89lxcoupe wrote:i kinda like the factory look, but if i could find a single ps bracket that would line up with my multi groove pulleys i would switch.
Well, I will be making one for my engine and if there is an interest, I can probably make several. I made a dual alternator bracket for my Durango a few months back and people showed interest so I did a run of about 20 and sold them all within 2 weeks so...
SLOWnSTEADY
Post  jasonf August 11th 2010, 6:30 pm
Doesn't bigblockfox.com or something like that make adapters so you just use your factory 5.0l front dress??
Post  res0rli9 August 11th 2010, 8:02 pm
I would like one of them if you make more Smile
OOPS: sorry I mis read, thought it was an alt. bracket.
Keirth
