What to use for starter?
Moodyblues
BigRigTech
rocketpony
It's a 600ci with 15:1 compression, and a c6 tranny.
So what do I get for a starter? I have a few factory starters from 5.0 stang but I guess that won't work.
rocketpony- Posts : 120
Re: What to use for starter?
I use a stock starter for a 92 F350 with a 460 but mine is only 11.4:1, no issues in the last 4 years with it.
BigRigTech- Posts : 763
If you're using a start retard of any kind I don't see why the late style 460 starter wouldn't roll it over. I use an old CVR for a 351W but I already had it laying round...
jbozzelle- Posts : 3705
Pretty hard to beat free replacement parts on a racecar. We use the 7.5L F350 deals with lifetime warranty...and they work.
maverick- BBF CONTRIBUTOR
EFI 460 starter here too.
So what make and model vehicle will I say when I go to auto parts store?
1996 F350 with 7.5L gas engine
Some oil pans won't accommodate just any starter. I have the small factory job ^^like they speak of and it won't fit my dry sump pan. I had to use the smaller jegs/summit starter you can clock the nose where you need it. Maybe you don't need that kind!
The 1.9 HP summit starter SUM-820048 is been good so far and $190 isn't bad , I've bought two of them for 460's , one 302 model and one for the RV with a 454 , they also make the 3.1 HP unit SUM-820048-M for $270 , and the 18 position thing is nice.
nuclearcobra- BBF CONTRIBUTOR
I know it's a lot of money but I use the TILTON super duty starter and in 20 years the same starter has never failed. After 15 years I sent it in to be serviced just because.
Ace
Ace
powerstrokeace- Posts : 1496
» Starter wiring , with solinoid on starter and fender
» GM Starter on Eliminator Block
» CSI 460 Starter
» Need Starter
» Recommend a decent starter motor
» CSI 460 Starter
» Need Starter
