Help figuring out nitrous
6jeff6
Help figuring out nitrous - Page 2 Empty Re: Help figuring out nitrous
Post  gmsmkr September 5th 2015, 10:24 pm
Bummer..... now you can put a glide in it!!!!
gmsmkr
gmsmkr
Post  6jeff6 September 5th 2015, 10:49 pm
C4s that weak?
6jeff6
6jeff6
Post  gmsmkr September 5th 2015, 11:14 pm
I have broke c4s with a 295hp 302 and really give them hell on the nitrous.... the old turbo car would eat a PA super comp c4 in about 75 passes
gmsmkr
gmsmkr
Post  6jeff6 September 6th 2015, 10:05 am
Ugh great
6jeff6
6jeff6
Post  supervel45 September 6th 2015, 1:53 pm
You are asking a lot from a C4, especially if you spay it. C6 TH400 or a Glide would be better, unless you are racing for big money and need every bit of weight savings and HP to the ground, with a 3 speed.
Post  6jeff6 September 6th 2015, 2:03 pm
I just can't afford a trans at this time. I can imagine there would be a lot of modifications to fit the others because of size alone
6jeff6
6jeff6
Post  supervel45 September 6th 2015, 2:41 pm
Then fix the C4 and keep in mind that it has limitations.
Post  gmsmkr September 6th 2015, 3:03 pm
Jeff , sent you a pm
gmsmkr
gmsmkr
Post  6jeff6 September 6th 2015, 3:04 pm
K. What would you recommend for a c6? I will start saving for it instead of nitrous. I'm guessing I'll need one to support around a 1000 because when I add spray I want to touch that high to get in 9s but want something you guys have run. I'm open to any trans and I had a built th400 behind my kenne belled 4.6 from jw but would kind of like to stay ford this time but like I said I'm open to real racers knowledge as dependability matters most and next year my son will run this car at track to.
6jeff6
6jeff6
Post  supervel45 September 6th 2015, 3:24 pm
I would recommend a Power Glide.
Post  6jeff6 October 26th 2015, 4:20 pm
Gap is 24 top 22 bottom but ford racing parts said up to 250 shot will be fine. Any thoughts?
6jeff6
6jeff6
Post  supervel45 October 26th 2015, 6:28 pm
That gap puts you at about .0055" per bore inch diameter on a 4.39" cylinder. Most of the recommendations I have seen where from .005" to .007" per/inch bore. I would not go over a 250 shot and would be conservative with the timing. Did you find out what brand and type ring pac. was used?
Post  6jeff6 October 26th 2015, 6:37 pm
Did not. I can call tomorrow?
6jeff6
6jeff6
Post  supervel45 October 26th 2015, 6:50 pm
Try to find out. If they are Moly I would not get to carried away with the gas.
Post  6jeff6 October 28th 2015, 5:38 pm
Missed the time to get that information but jet sizes are fuel side 055
Nitrous side 034
6jeff6
6jeff6
Post  supervel45 October 28th 2015, 6:05 pm
http://www.yellowbullet.com/forum/showthread.php?t=270143 NOS Adjustable PowerShot and Cheater jet charts, post #8, see for yourself. Too much fuel.
Post  whatbumper October 28th 2015, 6:22 pm
do not use whatever jetting chart you got that much fuel side from.
Post  supervel45 October 28th 2015, 6:40 pm
He got the car with the plate on it jetted that way.
Post  6jeff6 October 28th 2015, 6:52 pm
Wow that 034 isn't even shown. Looks like ordering jet kit is a must. Boy every step this cat was set up terrible.
6jeff6
6jeff6
Post  supervel45 October 28th 2015, 7:26 pm
You should post in the stuff wanted section, someone must have some jets laying around in the smaller sizes they don't use.
Post  6jeff6 October 28th 2015, 7:59 pm
Done deal thanks guys
6jeff6
6jeff6
Post  6jeff6 October 29th 2015, 12:05 pm
SS50USPEEDPRORINGS pack
16-16 3/16th
Top moly
Bottom cast iron
He suggested if I spray 250 go with bigger gap, bigger cam 256-266, and get heads ported .
Thoughts?
6jeff6
6jeff6
Post  kim October 29th 2015, 12:48 pm
keep the spray 150 or less. Plasma moly rings don't like high heat, high load. blows the moly coat right off them.
If you want to be a N20 player, new rings definly
kim
Post  supervel45 October 29th 2015, 1:13 pm
If it was my engine I would stop at an .082 N20 pill.
Post  6jeff6 October 29th 2015, 2:30 pm
K thanks.
This car is just trying to be a 10.0 car only and with what it would cost to go faster safety and motor wise maybe I should leave it and dial it there for one year then decide if I want to push it.
6jeff6
6jeff6
