Need header information
Need header information Empty Need header information
Post  Inthegarage September 10th 2015, 4:46 pm
I am getting ready to update my 52 Vicky................It has stock 429 exhaust manifold and I want to find a set of headers that will work for it............The main problem is with the steering box... I had to massage the stock manifolds to clear it....Any help appreciated..........
Inthegarage
Need header information Empty Re: Need header information
Post  maverick September 10th 2015, 6:39 pm
If you had to massage a manifold setup, this thing sounds like a candidate for custom headers.
Need header information Empty Headers
Post  Inthegarage September 10th 2015, 7:09 pm
That's what I was afraid of....................would be easier if I could fit a set that just needed to be worked a little...
Inthegarage
Post  maverick September 10th 2015, 7:31 pm
I guess that's an option...after searching to find the easiest set to modify, then cutting, rerouting, welding, painting or coating...provided you're not too fussy about the appearance.
Post  res0rli9 September 10th 2015, 7:38 pm
These should work.. just call and ask.
http://www.fordpowertrain.com/fpaindex/Fordpassenger1.htm
these are from an FE but the 429-460 look about same.
http://www.fordpowertrain.com/54-64FERP.htm
Post  Inthegarage September 10th 2015, 9:14 pm
Was thinking more along the line of these...............they look like I could snake a pipe around the steering...Car is floor shift and cable kick down....
https://s1203.photobucket.com/user/inthegarge/media/429%20headers.jpg.html
Inthegarage
Post  jeffgfg September 11th 2015, 9:09 am
Check Sanderson headers, they have a lot of shorty compact headers available. Check a set for an early F-100 with a 429/460. Hope this helps.
jeffgfg
Post  Inthegarage September 13th 2015, 5:18 pm
Thanks, I'll do that...........
Inthegarage
