Engine Knock worn bearings
FSU_Bronco
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Engine Knock worn bearings
Instead of an off shore crate crap engine, get one of the builders on here to do one for you. As much as some talk about the 1200hp etc.. they are just as capable of a long life quality 600hp street engine. Depending on where you live, im sure a member of thid board can provide you with something 100× the quality as you would get from a chain vendor. If thats a stock crank a .020 cut aint going to kill what your asking from it. A machine shop can cut that out and then run a thicker bearing shell.
kim- Posts : 700
kim wrote:Instead of an off shore crate crap engine, get one of the builders on here to do one for you. As much as some talk about the 1200hp etc.. they are just as capable of a long life quality 600hp street engine. Depending on where you live, im sure a member of thid board can provide you with something 100× the quality as you would get from a chain vendor. If thats a stock crank a .020 cut aint going to kill what your asking from it. A machine shop can cut that out and then run a thicker bearing shell.
Hell I would be happy with 300hp.
I don't really know who is or isn't a builder on here but I would be glad to talk to them to get some prices. I would be interested in seeing how much engine I could get for my budget from someone who knows how to buildem.
FSU_Bronco- Posts : 56
Where are you located will help also
69F100 wrote:Where are you located will help also
Tallahassee, Florida....
I just assumed the FSU would give it away
FSU_Bronco wrote:69F100 wrote:Where are you located will help also
That around 3 hours south of me I am in South Ga.
Update to this really old thread.
I ended up polishing the journals by hand to get groves out as best as possible with the crank still in the engine and the engine still in the bronco. It took a lot of time!
I spent most of the winter working on it on and off... as I got motivated.
Installed new Bearings, A high volume oil pump, and 20w 50. The knock is gone and the engine is running like new!
Spent less than $200 for everything.
FSU_Bronco wrote:Update to this really old thread.
HeHe ain't that sweet. I bet it lasts quite awhile and glad you got it going yourself on the cheap.
supervel45- Posts : 4499
Page 2 of 2 • 1, 2
» engine bearings
» Differences in types of engine bearings - what's the scoop?
» Morning funny....
» Head/piston question
» Morning funny....
Page 2 of 2
