Help with suspension
yellowhorse7
6jeff6
Help with suspension Empty Help with suspension
Post  6jeff6 October 19th 2015, 10:44 pm
[url=Help with suspension Th_20151017_160420_zps8sanpbjf]Help with suspension Th_20151017_160420_zps8sanpbjf[/url]
6jeff6
6jeff6
Help with suspension Empty Re: Help with suspension
Post  6jeff6 October 19th 2015, 10:52 pm
Drivers side rear tire keeps unloading. And from the video it never squats on that side. Lakewood drag shocks in rear with adjustments in the spring (big blue threaded adjustment). Full weld in subframe connectors. Anything else you need I can let you know.
6jeff6
6jeff6
Post  whatbumper October 19th 2015, 11:00 pm
These suspensions don't squat. Everything looks fine. All you need is an antiroll bar to keep the rear level when launching.
Post  6jeff6 October 19th 2015, 11:07 pm
What anti roll bar do you recommend?
6jeff6
6jeff6
Post  yellowhorse7 October 20th 2015, 11:03 am
6jeff6 wrote:What anti roll bar do you recommend?
Team Z, Wolfe, Race Craft, even UPR (even though most of their stuff is not up to standards)...
I'm sure that WhatBumper could even make you one...
yellowhorse7
yellowhorse7
Post  6jeff6 October 20th 2015, 11:52 am
I thought they mounted behind axle? I swear my 2000 gt had one mounted behind axle but maybe I'm wrong. I'll crawl under late tonight when I get back.
I've seen and heard good things about team z.
6jeff6
6jeff6
Post  whatbumper October 20th 2015, 12:12 pm
in front, behind, below. makes no difference.
for easy to install mass produced kits I'm a fan of the TRZ billet one but Team Z is very good as well. Ours are a little too heavy duty for your application. They are meant for 1500+ applications.
Post  6jeff6 October 20th 2015, 12:27 pm
That would make sense then. Thanks appreciate the help
6jeff6
6jeff6
Post  6jeff6 October 20th 2015, 10:12 pm
[url=Help with suspension 20151020_205617_zpsd8oowtdw]Help with suspension 20151020_205617_zpsd8oowtdw[/url]
6jeff6
6jeff6
Post  6jeff6 October 20th 2015, 10:14 pm
[url=Help with suspension 20151020_205433_zpsyq8wufd7]Help with suspension 20151020_205433_zpsyq8wufd7[/url]
6jeff6
6jeff6
Post  6jeff6 October 20th 2015, 10:16 pm
Drivers side is tightened all the way where the passenger side is elongated some. Suggestions?
6jeff6
6jeff6
Post  whatbumper October 21st 2015, 12:03 pm
apparently the aluminum pieces either aren't bolted onto the torsion bar or that little bar isn't good enough. We never use anything that small.
Post  supervel45 October 21st 2015, 3:42 pm
whatbumper wrote:apparently the aluminum pieces either aren't bolted onto the torsion bar or that little bar isn't good enough.  We never use anything that small.
You can see the bolt through the arm on the driver's side, but it does look like a cheesey setup that would flex a lot.
Post  whatbumper October 22nd 2015, 9:08 am
I couldn't tell if it was a bolt or some sort of set screw.
Post  supervel45 October 22nd 2015, 9:20 am
Both maybe. The one on the drivers side looks like it goes all the way through with a nut on the bottom, the passenger side looks like a bolt coming down from the top, hard to tell if it goes all the way thru.
Post  6jeff6 October 22nd 2015, 9:58 am
If u guys want more pics i can give you whatever? Also just put my 10.4 pass on photo bucket but if you slow it down you can see where I pedaled it out of the hole and was sawing like a sob.
6jeff6
6jeff6
Post  jbozzelle October 23rd 2015, 10:04 am
Disconnect both linkages from the housing and see if you can twist it with your hands. See if there is any play in the bar itself...
Post  Larry T October 24th 2015, 7:00 pm
their should be no preload on the bar adjustment but then again that setup is not ideal.
Larry T
Larry T
Post  6jeff6 October 25th 2015, 2:17 pm
The main bar is solid. I did find one broken bolt that connected aluminum piece to/thru bar. It's really tightened as far as it can go so I maybe screwed
6jeff6
6jeff6
Post  supervel45 October 25th 2015, 2:22 pm
I figured you would.
Post  gmsmkr October 25th 2015, 2:33 pm
Cut that crap out and put a real ARB in it..... spline or weld arms that bolt on arm $hit ain't worth the scrap
gmsmkr
gmsmkr
Post  6jeff6 October 25th 2015, 2:37 pm
Hope to make track next weekend then I'll spend the coin this offseason for that and getting nos hooked to break more
6jeff6
6jeff6
Post  supervel45 October 25th 2015, 2:41 pm
gmsmkr wrote:Cut that crap out and put a real ARB in it..... spline or weld arms that bolt on arm $hit ain't worth the scrap
You beat me to it, But Yea throw that POS in the trash before it causes you to wreck the car.
Post  6jeff6 October 26th 2015, 4:18 pm
Sent payment for better anti roll bar ...
6jeff6
6jeff6
Post  DILLIGASDAVE October 26th 2015, 6:20 pm
Just how small OD was the old anti-roll's torsion tube/bar anyway? Might be an optical illusion but the pics kinda make me think either it's a 1" OD torsion bar with giant aluminum arms, or regular sized aluminum arms with a 3/4" OD torsion bar.
