8.8 Power Limits
MustangDan
gmsmkr
jc10000rpm
8.8 Power Limits Empty 8.8 Power Limits
Post  jc10000rpm October 31st 2015, 6:22 pm
what is the max power recommended through a 8.8 setup ??
pics or links would be nice, new build should put us around 5.0 1/8th
jc10000rpm
8.8 Power Limits Empty Re: 8.8 Power Limits
Post  supervel45 October 31st 2015, 6:51 pm
It would depend on the weight and 60ft times quite a bit.
Post  gmsmkr October 31st 2015, 6:56 pm
35 spline axles with elem and a spool with team Z bracing and 9"ends with tubes welded to center and you got your self a well built 8.8 we have been 5.50s on this same set up@ 3275lbs
If your starting from scratch and dont have any 8.8 parts I would do a 9" it will cost about the same
gmsmkr
gmsmkr
Post  supervel45 October 31st 2015, 7:33 pm
I would start with the 9" also if you don't have a built 8.8" yet too.
Post  MustangDan October 31st 2015, 8:11 pm
This post is for me I have a built 8.8 and been 5.40 n/a and 1.20 60 on a no prep look to go 4.90 n/a thinking I need a 9"
MustangDan
Post  gmsmkr October 31st 2015, 8:34 pm
Dan, pull the difference cover check the gears and axles twist if all looks good give it a go. I would put a well built 8.8 on the line if all checks out good... jmo
gmsmkr
gmsmkr
Post  MustangDan October 31st 2015, 8:37 pm
Yeah you can't get a better 8.8 then I have now and yes all looks perfect
MustangDan
Post  gmsmkr October 31st 2015, 8:39 pm
MustangDan wrote:Yeah you can't get a better 8.8 then I have now and yes all looks perfect
Beat the piss out of it then Wink
gmsmkr
gmsmkr
Post  MustangDan October 31st 2015, 8:43 pm
Do you do fb ? If so check out my fox page
(For the love of fox body ) <<
MustangDan
Post  MustangDan October 31st 2015, 9:27 pm
MustangDan
Post  jc10000rpm October 31st 2015, 10:12 pm
to be clear, the 8.8 in it is already braced and setup well and running mid 5's, looking for some
examples of people running in the high 4's on a 8.8.
jc10000rpm
Post  whatbumper October 31st 2015, 11:15 pm
We have a customer that runs 4.70's with an 8.8 in a 2920lb car on a radial that goes 1.08-1.10 every pass.  We have to put gears in every 30 or so passes to make them live.  I'll post pictures of the bracing on it.
Post  supervel45 October 31st 2015, 11:28 pm
It likely has to a lot to do with the safety margin of it, who want's to risk wrecking at those speeds to save a few bucks on the rear end. affraid
Post  whatbumper November 1st 2015, 12:34 am
supervel45 wrote:It likely has to a lot to do with the safety margin of it, who want's to risk wrecking at those speeds to save a few bucks on the rear end. affraid
What would break on a built 8.8 that would wreck you that wouldn't wreck you with a 9"?
Post  supervel45 November 1st 2015, 2:39 am
I would suspect the pinion gear would let go first on a 8.8". If it does, I don't see that being a good thing, especially if the car is loose when it happens by chance, like some of the no prep pedal fest races.
Post  MustangDan November 1st 2015, 9:01 am
Alex Hayes is a n/a BB guy and said he was breaking the pinion gear
MustangDan
Post  richter69 November 1st 2015, 10:42 am
and thats why you upgrade to a 9"
Post  MustangDan November 1st 2015, 10:49 am
Yeah that's the hole point of this post lol
MustangDan
Post  gmsmkr November 1st 2015, 11:57 am
The 8.8 will live with serious power but you will have to stay on top of the maintenance to keep it happy... just like anything else hi-performance. The question is how often do you want to down it and check on parts
gmsmkr
gmsmkr
Post  whatbumper November 1st 2015, 12:02 pm
He puts rear ends in a unique situation that most on this site dont see: rpm.
I was really thinking structurally but I see your point about the gears. We get about the same use out of 8.8 gears and small pinion 9" gears. If I was building a rear end fo a car running faster than 5.20's or so it would have a big pinion 9". It'll last a long time. For heavy radial cars running deep into the 4's id run 9.5" gears. Cars on slicks can run 9" gears forever it seems.
Post  maverick November 1st 2015, 3:32 pm
I tune a car for a friend with an 8.8" in his Fox. When it was a high to mid 5 sec. car all was well....pretty much normal life for a raced 8.8". Now that it's a 5.0 car, soon to go 4.90's, the pinion gear climbs the ring gear and occasionally comes out looking like a chicken leg. He's fixing the 8.8 one last time and shopping for his 9" now.
Post  MustangDan November 1st 2015, 4:05 pm
Marcus Warwick is building me a chromoly fabricated 9 inch
MustangDan
Post  whatbumper November 1st 2015, 11:43 pm
Here's the junky ole 9" housings we put out. This one is in a mopar if you are asking about the backwards shock brackets.  Custom jig built fabricated housings.  Jig itself is pretty cool but we're not posting pics of it.  Cool
https://www.facebook.com/2JMFab/photos/a.967041470003473.1073741846.416404781733814/967041656670121/?type=3&permPage=1
Post  MustangDan November 2nd 2015, 11:09 am
https://m.facebook.com/groups/1525133584437397?view=permalink&id=1671482023135885
This is my new rear end
MustangDan
Post  Art November 2nd 2015, 12:00 pm
We have an 8.8 in our car that is built and braced. 35 spline axles and 9" ends. Car has been mini tubed. The car weighs 3250 lbs and we run a turbo 400 and also a pg. Best so far has been a 4.90 @ 146.8, with nitrous. This is a BBF combination. We have broke one gear, that was a 4.30 ratio. In talking with others for some reason the 4.30s break. We have not had any problems with 3.73, 3.90, or 4.10. We have run 275 drag radials as well as 28 x 10.5 slicks.
Also know someone that runs nitrous x and/or ultra street with an 8.8 and runs 4.70s-4.80s with a nitrous sbf set up.
Art
