Viktor air gap intake
+11
68galaxie
jeffgfg
gmsmkr
nord315
DanE
Bart Knox
15 posters
Page 5 of 6 Previous  1, 2, 3, 4, 5, 6  Next
Viktor air gap intake - Page 5 Empty Re: Viktor air gap intake
Post  Bart Knox January 17th 2016, 2:06 pm
What about a dry sump pan
Bart Knox
Bart Knox
http://W. B Knox&son LTD Huntsville Ontario
Post  Bart Knox January 20th 2016, 1:08 pm
Can anyone tell me ruffly how much to take off heads dove-c to get 70cc's ?
Bart Knox
Bart Knox
Post  Bart Knox January 22nd 2016, 4:21 pm
Found a crack in the block... Just in the water jacket patchable he said... Just a set back no big deel
Bart Knox
Bart Knox
Post  Mike R January 22nd 2016, 9:18 pm
Don't let him arc weld it. Cast iron can NOT be electric welded, it must be brazed.
Post  1bad56 January 23rd 2016, 12:16 am
EDITED:
Bart Knox wrote:... I'm getting a rear sump pan and wondering if I just change the pick up or need a different pump... The reason I need to know is I can sell the pump to a guy thats having a 460 built for a Lincoln
Just change the pick-up to one for a rear sump.
1bad56
Post  Bart Knox January 23rd 2016, 9:51 am
Iv been looking at pans and the shalowest pan in the centre i could find was the Ford racing M-6675-A460 and was told that i had to use the M84D pump with it. As far as the block he wants to drill and pin each end of the crack and fill it with Im not sure what. He said the heat from brazzing could crack it farther. Brazzing was my first thot but he said hes fixed much bigger cracks and not to worry.
Bart Knox
Bart Knox
Post  68galaxie January 23rd 2016, 12:08 pm
Personally I would not use a cracked - and hopefully fixed block.
There are plenty of 460 blocks around. Why take the chance on this cracked block?
Will he guarantee success - and cover the cost entirely if the crack fix fails?
Source another block that checks out.
68galaxie
68galaxie
Post  Bart Knox January 23rd 2016, 12:18 pm
The crack is about 4 inches in totale and is going to take my old heads for payment of fixing the crack. I do no ware there is a 80s block from a cube van but wasnt sure if my crank would fit been internaly balanced. I can look for a nother pre 79 block but everything got scraped around here when the price was high
Bart Knox
Bart Knox
Post  Bart Knox January 24th 2016, 10:49 am
I found anuther block. 77 was borred out 30 over 10 years ago and never totaly ressembled. Going to look at it today and if it checks out ill grab it.
Bart Knox
Bart Knox
Post  Bart Knox January 24th 2016, 9:43 pm
I picked up this block for free. 40 over never totaly ressembled crank is seized and would need bored again. How far can you go befor needing to sleeve cylinders.
Bart Knox
Bart Knox
Post  Bart Knox January 24th 2016, 9:50 pm
Block is D1VE-6015-A2B
Bart Knox
Bart Knox
Post  68galaxie January 25th 2016, 4:15 pm
The cracked block is a D1VE?
Or the new one you found?
I would sonic check any block going 0.060" or more
68galaxie
68galaxie
Post  Bart Knox January 25th 2016, 10:51 pm
There both d1ve blocks. If you do have to sleeve do you do all cylinders or just the one that get bored throu to the cast?
Bart Knox
Bart Knox
Post  68galaxie January 25th 2016, 11:41 pm
Does the new block need a sleeve?
68galaxie
68galaxie
Post  jeffgfg January 26th 2016, 10:08 am
Most 429-460 blocks can easily take a .060 overbore barring any unusual core shift. A sonic check is a good safety measure. Many blocks have been taken out to .080 and a few rare blocks have been taken out to 4.500 bores without sleeves. No overheating issues from just the .060 overbore, maybe other issues caused it. Have you mic'ed the bores? maybe you can just hone the cylinders for new pistons.
jeffgfg
Post  Bart Knox January 26th 2016, 9:15 pm
The guy doing the motor just looked at it and said it would bored again. Also the pistons that i was told to get only come in 30 and 60 over I think. That as far as I got. He looked in the back of the truck at it and brot it home.
Bart Knox
Bart Knox
Post  Bart Knox February 12th 2016, 10:07 am
So i ended up having the original block fixed he said it will be fine we'll see. I picked up a set of brand new headers off a guy in town for $150. Said they were for a 91 f250 that he never did anything with. I was wondering if theres any differents in 2 weel drive and 4 weel drive headers? He also said i can take the motor for $100. I was hoping i could use the oil pan and pickup tube he said the oil pan was good condishon and repainted
Bart Knox
Bart Knox
Post  Bart Knox March 14th 2016, 7:33 am
Is a stud kit for the heads a good idea for what im doing or a wast of money
Bart Knox
Bart Knox
Post  supervel45 March 14th 2016, 12:41 pm
I think it's a waste. If you are going to stay N/A I don't see the point for what you are doing.
Post  Bart Knox March 14th 2016, 2:49 pm
The guy thats building my motor wanted to but I thot $500 was a lot for studs I probably dont need. Is $500 what they cost?
Bart Knox
Bart Knox
Post  supervel45 March 14th 2016, 5:57 pm
You oboviously have internet check around and see. Sounds a little steep to me.
Post  Mike R March 14th 2016, 8:39 pm
Bart, $500 for head studs is a rip off. You come here asking questions and get answers from some of the most knowledgeable guys around, then you take your engine to some local doof and listen to him. You need to listen to what these guys tell you and tell your machinist/assembler what you want done, not let him do what he wants to do with your money. If he doesn't want to do what you want you need to find another guy who will do what you want. No one here is going to steer you wrong, listen to what they say, there's probably more combined knowledge here than anywhere else on the planet
Post  supervel45 March 14th 2016, 11:41 pm
Bart I don't know what the Canadian dollar trade ratio is, and I was also trying to be nice with my response, hint.
Post  Bart Knox March 15th 2016, 12:09 pm
Thanks guys... I dont doubt your knowledge. When I started this thread alot of stuff didnt make cents to me but after doing everything twice and wasting money I no better... $500 Canadian = $350 U.S plus shipping and buddy probably marked up the price. The motors almost done now. Buddy argued the decking and everything els that you guys told me to do... The next motor I do I'll do some more research and find someome that knows what hes doing. Thanks guys...
Bart Knox
Bart Knox
Post  Bart Knox March 23rd 2016, 8:37 pm
Im getting the motor back right soon and im looking for a cheaper aftermarket clutch kit... The transmission is a t18 with a 90s aluminum bellhousing and rebalanced flywheel. Anyone have any suggestions???
Bart Knox
Bart Knox
