Anybody? how to convert head flow figures from 32" to 28"H20 ?
As the title says.. I've tried google and can't find the info out there...??
nascar429- Posts : 91
Re: Anybody? how to convert head flow figures from 32" to 28"H20 ?
Divide the flow number by 8, then multiply that number by 7. If it works it was just a lucky guess.
supervel45- Posts : 4499
nascar429 wrote:As the title says.. I've tried google and can't find the info out there...??
Email Charlie I think he has the formula. Randy Malick may have it too.
This is very easy to figure:
Flow at first test pressure X the square root of the second test pressure divided by the first test pressure equals the flow at the new test pressure..
In your case multiply by .935 to go from 32 to 28 inches of test pressure.
DaveMcLain- Posts : 399
dfree383 wrote:nascar429 wrote:As the title says.. I've tried google and can't find the info out there...??
Email Charlie I think he has the formula. Randy Malik may have it too.
I just use the Superflow conversion chart and it does not show 32"; (just 28", 30" and 35").
http://www.lindseyracing.com/LR/Parts/TGHEADS.html Scroll down, the SuperFlow chart is in there, you will have to wing it, as 32 is not in there as Randy said.nascar429 wrote:As the title says.. I've tried google and can't find the info out there...??
Why on earth would you have to "wing it"? All you have to do is multiply your flow numbers at 32 inches by .935 and you'll have your numbers at 28.
Thanks Guys..
For your help its appreciated..
Mr McLain is correct I had a look through some old flow sheets i forgot about..and found the conversion rate under there notes.. simply multiply by .935
