Dana 60
Dana 60 Empty Dana 60
Post  cool40 November 14th 2015, 11:47 pm
Is this for sure a Dana 60? Where can I get a 620 gear ? Dana 60 20151114_180338
Dana 60 Empty Re: Dana 60
Post  Bret Powell November 15th 2015, 10:45 am
That is a reverse cut Dana 60. You can't buy a 6.20 gear for that, they never made them. The lowest gear you can buy is a 5.38.
Bret Powell
Post  cool40 November 15th 2015, 12:26 pm
Bret Powell wrote:That is a reverse cut Dana 60. You can't buy a 6.20 gear for that, they never made them. The lowest gear you can buy is a 5.38.
that's what it has in it now. I have a 106 rear but I can't remember the gear but I know it's lower, 58? Something. Now what? Question
Post  nord315 November 15th 2015, 12:45 pm
Can you go to a chain drive so you can slow down the front drive shaft so that the gearing matches?
nord315
Post  cool40 November 15th 2015, 12:50 pm
nord315 wrote:Can you go to a chain drive so you can slow down the front drive shaft so that the gearing matches?
I have a Profab drop box but I don't know how it works,lol....this 4x4 stuff is new to me. This is a prostock pulling truck " under construction " Laughing
Post  nord315 November 15th 2015, 1:20 pm
I have never used a drop box, assuming that it drops both drive shafts and not only the front, I do not believe that you can change the speed of only the front shaft. Can you change the gear ratio of the drop box and than change the rear end gearing to match the front?
nord315
Post  cool40 November 15th 2015, 1:31 pm
nord315 wrote:I have never used a drop box, assuming that it drops both drive shafts and not only the front, I do not believe that you can change the speed of only the front shaft. Can you change the gear ratio of the drop box and than change the rear end gearing to match the front?
I suspect that's what I'll have to do. The profab is a quick change gear drive that has lots of ratios.
Post  jones November 16th 2015, 8:51 pm
My 10" gear box is something like you would need. You can overdrive or under drive the front axle how ever you want. It is a quick change as well.
Dana 60 D79988C0-C631-4C3B-971C-1B1BDF1CD66F_zpsfwdrg4gn
jones
