Dana 60
+7
kjett
10.0
samiam
11 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Dana 60
I have a Dana 60 hp with 35 spline Detroit locker and 5.38's. It's a ball joint mid 90's I guess and has drive flanges,no lockouts. The brakes are home made stuff with small calipers,was used on pulling truck, and has had some brackets welded on and some cut off but nothing that can't be repaired. What's it worth?
![Question](https://2img.net/i/fa/i/smiles/icon_question.gif)
Re: Dana 60
A used Detroit Locker for a Dana 60 will go from $300- to $500, so I thinking $7-900 for the complete axle.
supervel45- Posts : 4493
Re: Dana 60
A ball joint 60 will pull 7-9 hundred up here
Mike R- Posts : 1381
Re: Dana 60
I was thinking with the locker and gears it should be a $1000 axle?
![Suspect](https://2img.net/i/fa/i/smiles/suspect.gif)
Re: Dana 60
Maybe I am being too conservative, I don't look at the front axle pricing much. Try to get what you can out of it.
Re: Dana 60
Im just assuming its a ford front, were im at , Cal. ,, they seem to be a bit tougher to come by, with the detroit Id say an easy 1000. but end game its worth what you let it go for.
samiam- Posts : 240
Re: Dana 60
When I was into trucks, the ford front 60's were a dime a dozen and the chevy 60's were hard to find
John Myrick- BBF CONTRIBUTOR
Re: Dana 60
Well this 60 is gona get the ends put on a 70! Housing ends are so dang high I'm better off cutting it up! I picked a Dana 70 rear housing for $100 today so it's on now!
![Shocked](https://2img.net/i/fa/i/smiles/icon_eek.gif)
Re: Dana 60
Dana 70s are no better than 60s, would be a waste of time.
Now if you transferred the ends to an 80, then you would be gaining something.
The 60s holdup pretty good in the front, the 70s would last no better, other than less gear choices.
You'll find no used 70 gearsets , where 60 gearsets are plentiful.
10.0- Posts : 54
Re: Dana 60
50's and 70's are pretty rare in the used market.
Re: Dana 60
the 70 has a 10.5" ring gear10.0 wrote:Dana 70s are no better than 60s, would be a waste of time.
You'll find no used 70 gearsets , where 60 gearsets are plentiful. Â
![Idea](https://2img.net/i/fa/i/smiles/icon_idea.png)
Re: Dana 60
we will see how a centered 70 works for pulling! The 60 is history!samiam wrote:keep us posted. Id like to see how its done
![Dana 60 20160224_191924](https://2img.net/h/i948.photobucket.com/albums/ad328/cool40/Mobile%20Uploads/20160224_191924.jpg)
Opened up to 3 5/8 for the 70 axle
![Dana 60 20160224_191822](https://2img.net/h/i948.photobucket.com/albums/ad328/cool40/Mobile%20Uploads/20160224_191822.jpg)
Re: Dana 60
New to me 70 ![Dana 60 20160221_095509](https://2img.net/h/i948.photobucket.com/albums/ad328/cool40/Mobile%20Uploads/20160221_095509.jpg)
Re: Dana 60
Chop chop chop it up
![cheers](https://2img.net/i/fa/i/smiles/icon_cheers.png)
Re: Dana 60
The 70 got circumcision today .
![Dana 60 20160225_181828](https://2img.net/h/i948.photobucket.com/albums/ad328/cool40/Mobile%20Uploads/20160225_181828.jpg)
![Laughing](https://2img.net/i/fa/i/smiles/icon_lol.gif)
Re: Dana 60
Slick deal with the 60/70 setup. I'm building a 609 centered front for my mud truck. Uses a 9" housing with D60 outers from an '05 F550 and up D60 and unit bearings. Will have 35 spline center with 4340 axles and 1410 joints. Strength of the 60, weight just a bit more than a D44!
kjett- Posts : 1169
Re: Dana 60
I give the 9" some thought but I was afraid it wouldn't hold up in a pulling deal.kjett wrote:Slick deal with the 60/70 setup. I'm building a 609 centered front for my mud truck. Uses a 9" housing with D60 outers from an '05 F550 and up D60 and unit bearings. Will have 35 spline center with 4340 axles and 1410 joints. Strength of the 60, weight just a bit more than a D44!
![Embarassed](https://2img.net/i/fa/i/smiles/icon_redface.gif)
Re: Dana 60
![Twisted Evil](https://2img.net/i/fa/i/smiles/icon_twisted.gif)
![Dana 60 20160227_163554](https://2img.net/h/i948.photobucket.com/albums/ad328/cool40/Mobile%20Uploads/20160227_163554.jpg)
Re: Dana 60
do you do about gears, or is the rotation not effected
samiam- Posts : 240
Re: Dana 60
gears are the same. Ford hp 60 is the odd one for gears,dodge and Chevy fronts are same as rearend also. I'm trying to decide on arb or Detroit locker.samiam wrote:do you do about gears, or is the rotation not effected
Re: Dana 60
http://www.ebay.com/itm/D70-HD-DETROIT-LOCKER-NEW-SURPLUS-/272151292775?hash=item3f5d7b2b67:g:vhQAAOxywh1TBMwc&vxp=mtr Not real happy with sleezebay but, saw this.
Re: Dana 60
http://www.ebay.com/itm/D70-HD-DETROIT-LOCKER-NEW-SURPLUS-/272151292775?hash=item3f5d7b2b67:g:vhQAAOxywh1TBMwc&vxp=mtr If you can use it or want it, here it is under best offer. He also has a lot of other differential parts.
Re: Dana 60
http://www.ebay.com/itm/D70-HD-DETROIT-LOCKER-NEW-SURPLUS-/272151286701?hash=item3f5d7b13ad:g:vhQAAOxywh1TBMwc
Re: Dana 60
Thats a bargain! Hell he has 4, I may buy 2!
Page 1 of 3
