7.3 powerstroke help!!
gmsmkr
My 99 f350 just recently started making a hissing sound under part throttle it goes away when I give it throttle and let completely off. Driving it down the road it sounds like it's coming from the dash... what could it be. Thanks for any help on this
gmsmkr- Posts : 1364
Re: 7.3 powerstroke help!!
vacuum leak does your heat/ac controls work right
Exhaust backpressure valve, normal in cooler weather. Mine has been deleted
All the controls are working great as they should69F100 wrote:vacuum leak does your heat/ac controls work right
I thought about the EBPV when I first heard it but even when the truck was up to temp it still made the noise only at around 1500-1700 rpm holding it consistent.richter69 wrote:Exhaust backpressure valve, normal in cooler weather. Mine has been deleted
How do I delete the EBPV and will it hurt anything
As long as the outside temps are cold it will still do it, unplug it to verify
richter69 wrote:As long as the outside temps are cold it will still do it, unplug it to verify
Ok thanks I will do that this evening
Or the EBPV sensor tube from the exhaust manifold to the sensor could be clogged too. Fabio would know for sure. I know I had to clean mine once before because it was causing problems.
jbozzelle- Posts : 3705
Delete it. Its a pain in the ass when it seizes closed at some point..LOL....I would check the up pipes too, they can his if they are leaking at the turbo collector.
BigRigTech- Posts : 763
Well I think found the problem the small tube has rust holes in it
How do you delete the EBPV ???
My truck started nocking going up big hill towing trailer. Runs fine around town and no hills.
I just took off the cat. converter, it was not plugged, you could see through it.
Bill Heard- Posts : 115
» Need help with my powerstroke
» 6.0 Powerstroke's
» Hey Jon 05 powerstroke question?
» 6.0 Powerstroke help
» 7.3 powerstroke help asap
» 6.0 Powerstroke's
