Need help with my powerstroke
Need help with my powerstroke Empty Need help with my powerstroke
Post  lghting94 February 2nd 2010, 9:24 am
Guys I need a little help(well actually a lot but thats another story). I just traded my 1995 7.3 powerstroke 2wd truck for a 2002 7.3 powerstoke 4wd both crewcab duallys and now my new truck has an issue. when you take off sometimes it acts like it has a flat spot in the throttle it will also "chug" every so often driving down the road. I have replaced the cam sensor and throttle pedal assembly and neither fixed the problem any suggestions on what to check next? Thank you for your assistance. Todd
lghting94
lghting94
Need help with my powerstroke Empty Re: Need help with my powerstroke
Post  richter69 February 2nd 2010, 9:31 am
does the check engine light come on when it happens?
Exhaust make a restricted sound when it happens? Could be the cold weather has the ebp trying to close, pushing the throttle down harder will usually make it back off and the truck will go. You can disconnect it it to see if its the culprit, 2 wire connector under the turbo. Its a normal operation......its just rying to warm the engine up.....took mine off lol.
Post  lghting94 February 2nd 2010, 10:03 am
The check engine light doesnt come on and it happens even after engine is warmed up I here the ebv when its cold and know what that is this is different and I may not be explaining it right but when you go to accelerate preee the go pedal and it acts as if it dies and then comes back then it runs great thru acceleration but when cruising it act like every so often it drops to idle and comes back.
lghting94
lghting94
Post  richter69 February 2nd 2010, 10:58 am
Does it have adj pedals?
Post  lghting94 February 2nd 2010, 11:03 am
no it doesnt have adjustable pedals
lghting94
lghting94
Post  richter69 February 2nd 2010, 2:21 pm
there were recalls on the adj pedal models for the ap............if the accel pedal voltage goes out of range it will default idle only. You'll need a scan tool or a voltmeter to look for this.
Post  lghting94 February 2nd 2010, 2:44 pm
could the injection control pressure solenoid(top of engine in front of drivers head) be causing this if it is going bad? I already replaced the throttle pedal assembly that didnt help.
lghting94
lghting94
Post  the1969fordguyinky February 3rd 2010, 11:11 am
Under the KISS method, you did change the fuel filter, right?
the1969fordguyinky
the1969fordguyinky
Post  richter69 February 3rd 2010, 12:33 pm
lghting94 wrote:could the injection control pressure solenoid(top of engine in front of drivers head) be causing this if it is going bad? I already replaced the throttle pedal assembly that didnt help.
I'll pm you my number, too much crap to type out.
Post  lghting94 February 3rd 2010, 5:47 pm
changed the fuel filter today and no change called and talked to jon got a few things to check now thank will update with results. todd
lghting94
lghting94
