E8ZN-A460
kim
T-T 63 Galaxie
E8ZN-A460 Empty E8ZN-A460
Post  T-T 63 Galaxie November 22nd 2015, 2:17 pm
I have an E8ZN-A460 Block….its a new block that is assembled, but never ran. just looking for info on the block and what it would be worth…its not going to work with my build….thanks
T-T 63 Galaxie
E8ZN-A460 Empty Re: E8ZN-A460
Post  T-T 63 Galaxie November 22nd 2015, 2:32 pm
also have a hew set of M-6049-A429 heads that are new also…..never ported….dont know to much about there either…i know they don't make them anymore either..
T-T 63 Galaxie
Post  bbf-falcon November 23rd 2015, 2:00 am
T-T 63 Galaxie wrote:also have a hew set of M-6049-A429 heads that are new also…..never ported….dont know to much about there either…i know they don't make them anymore either..
Those heads will make decent power for what they are. Its been a while since I owned a set but some of either the early/later build dates had some issues w/valve clipping on higher lift roller cams. Not a BIG deal,i just trimmed the valve diameters a shade and they were good to go.
Post  T-T 63 Galaxie November 23rd 2015, 9:39 pm
anyone now anything about the block…it does have 2 top bell housing bolt holes...
T-T 63 Galaxie
Post  Lem Evans November 24th 2015, 12:10 pm
Picture?
Post  kim November 24th 2015, 7:00 pm
Its the M6010 A460 block. Your reading a casting number, versus the part number. The casting number identifies the date of cast, 88, Z destined for mustang.. lol.. and N, non production Best as I can decipher.
kim
Post  T-T 63 Galaxie November 24th 2015, 11:10 pm
that is the number stamped on the side of the block….ill get pics this weekend
T-T 63 Galaxie
Post  kjett November 25th 2015, 8:55 am
is it a 4 bolt block with screw in freeze plugs?
kjett
kjett
Post  T-T 63 Galaxie November 25th 2015, 6:54 pm
kjett wrote:is it a 4 bolt block with screw in freeze plugs?
yes it is…..
T-T 63 Galaxie
Post  supervel45 November 25th 2015, 8:31 pm
http://www.network54.com/Forum/85220/thread/1115687127/Need+help+to+ID+SVO+A460 It's a mystery block, LoL. According to my old SVO book the A460 block came out in the summer of 1987 and they list them as a M-6010 back then, so if the 8 indeed is 1988 it was one of the early blocks.
Post  T-T 63 Galaxie November 26th 2015, 2:59 pm
those are the numbers on it…there are no 6010 numbers….o would post pics, but i can't get it to work on this site..
T-T 63 Galaxie
Post  BIGINCH'S November 26th 2015, 4:13 pm
What is the bore size now are you wanting to sell block and heads -interested if you are
BIGINCH'S
Post  Lem Evans November 26th 2015, 5:10 pm
T-T 63 Galaxie wrote:those are the numbers on it…there are no 6010 numbers….o would post pics, but i can't get it to work on this site..
6010 is the base part number for any Ford block.
Is the block 10 or 18 bolt? Two or 4 holes in the middle of the lifter valley?
Post  T-T 63 Galaxie November 26th 2015, 7:23 pm
those 6010 numbers are not on the block…it is a 10 head bolt block.
T-T 63 Galaxie
Post  T-T 63 Galaxie November 26th 2015, 7:28 pm
BIGINCH'S wrote:What is the bore size now        are you wanting to sell block and heads -interested if you are
ill check the bore size tomorrow….its supposed to be a 518….its all new….h beam rods….i think its a cast steel crank….forged pistons….heads are a429…new also ….never ported….ill have to check on the cam…yes i want to sell it…i just wanted more info before i list it…..i need a 18 bolt set up and much better heads...
T-T 63 Galaxie
Post  Lem Evans November 26th 2015, 7:36 pm
You are missing what I am telling you. It does not matter if it's on the block or not.....all Ford blocks are 6010...case in point is M-6010-A460 or D9TZ-6010-A are both blocks......just like all part numbers with a base of 6500 are lifters.....6701 are all rear main seals.
Being that that block is 10 bolt for the heads it's an older unit.
The numbers that are cast with the block are engineering numbers.......not a part number or casting number.
Post  T-T 63 Galaxie November 27th 2015, 10:50 am
gottcha….dont know much about the 429-460's I've always had chevy motors in my race cars….dont like cross breading so i want to put the 429-460 base in the galaxie. the motor i have isn't going to work for what i want to do. just wanted to find out more about it before i list it for sale…ill get pics of it today . if anyone is interested i can email pics to them...
T-T 63 Galaxie
Post  T-T 63 Galaxie November 27th 2015, 5:10 pm
i have pics if anyone is interested….i can email them to you…..thanks
T-T 63 Galaxie
Post  powerstrokeace December 24th 2015, 10:57 pm
I just want to confirm you have an older A460 from motorsports block. im guessing it was built some where around 1990-2003 roughly. before it was revise and they started with the 18 bolt head pattern. i have the same block that was assembled in the early 1990"s and been though 3 maybe 4 owners. we finally had a rod failure and now it will get 2 sleeves and bores to 4.600 and get a 4.50 or 4.75 crank and not sure what we'll do for heads but it will be a "A" head deal
in order to sell it you'll need to get more info on deck height and bore size to inform the buyer what your selling.
hope this helps
Ace
powerstrokeace
powerstrokeace
