comp cams part # 1330-16 ?
comp cams part #   1330-16  ? Empty comp cams part # 1330-16 ?
Post  fastford600 November 29th 2009, 12:58 pm
will part # 1330-16 from com cams work on a bbf a460 head motor? they are 1.7 that why i asked
logan
fastford600
fastford600
comp cams part #   1330-16  ? Empty Re: comp cams part # 1330-16 ?
Post  Lem Evans November 29th 2009, 1:15 pm
Sure they will 'work' . Just be down on lift/power a little .
Post  David Cole November 29th 2009, 1:17 pm
They are listed for use with max diameter valve springs of 1.500. I've not seen any A460 heads with springs that small.
Post  Lem Evans November 29th 2009, 1:30 pm
David , is this from a retailers site ? The Comp catalog does not address the spring dia .
Post  fastford600 November 29th 2009, 1:34 pm
Lem Evans wrote:David , is this from a retailers site ? The Comp catalog does not address the spring dia .
lem so do thay make them 1.73? will thes work?the 1.7 idk ineed to know
fastford600
fastford600
Post  fastford600 November 29th 2009, 1:53 pm
thanks lem for the call
fastford600
fastford600
Post  David Cole November 29th 2009, 1:54 pm
That is what's listed on them from Summit's site:
http://www.summitracing.com/parts/CCA-1330-16/
That may or may not be correct though. We know the Crower SS rockers will work with the TFS A460 springs at 1.640, even though Crower lists a 1.56" as max diameter.
BTW Lem, went to the last race of the year for me yesterday. 6 passes. All 4.69-4.70. Best 60' of 1.025
Post  Lem Evans November 29th 2009, 5:05 pm
Cool
Post  c.evans November 29th 2009, 5:36 pm
Damn Boy Exclamation Uncle Charlie is proud of you Exclamation Laughing You should be happy, great 60' times and VERY consistent Cool You can win big money races with that. I know the car is an American Racears swing-arm deal, and they are kinda' heavy, so how much does it weigh with you in it? Around 2150 or so?
Charlie Evans
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  DanH November 29th 2009, 10:06 pm
the less ratio (1.70)rockers will give up .010" to .020" lift(approx, depends on lobe lift) can still keep total duration by tighten up the lash
DanH
