Cam question
OldRedFord
Cam question
Ok so I got a cam and lifter kit from Summit. Quite surprised to get it out of the box and there is no spec for valve spring pressures on the cam card nor anything about break in procedure. Plenty of info on installing the cam and lifter preload etc.
http://www.summitracing.com/parts/SUM-K3500/
Im hoping FRPP M-6513-A50 springs are not too stiff.
I thought all camshafts stated spring requirements.
OldRedFord- Posts : 465
Re: Cam question
There are several cams sold without any recomended valve spring requirements. All the FRPP camshafts come readily to mind and there certainly are a bunch of other cams, (expecially those generic grinds stuffed into different boxes), which rely on the customer to find out that information through other avenues.
Re: Cam question
Through other avenues? So like calling tech or the internet?
Re: Cam question
this is the reason I never buy from the Scummit or Jeggyy I want to have a small place in the decisions on my camshaft selection..... and besides they are mostly Chebby guy's so when you mention ford they say oh well we have chebby stuff ...................
the Coug- Posts : 3055
Re: Cam question
I think I should have gone with a custom grind
*Say it with me....noobs included*
From one of the vendors on this site.
Re: Cam question
From one of the vendors on this site.OldRedFord wrote:I think I should have gone with a custom grind
95lightiningguy- Posts : 570
Comp Cams.
Comp Cams 940 is 1.45 dia, 110 at 1.8 and 240 at 1.3, 260 lbs spring rate.
fordman460- Posts : 100
Re: Cam question
should be a recommeded spring part num on cam card? comp cams always gives a num for springs with cam
BOSS 429- Posts : 2372
Re: Cam question
You are not going to need a whole lot of spring with that cam and that Comp spring someone just recommended looks like a good choice to me. In my opinion you should be fine with about 100lbs seat and about 240lbs open load. It should work fine.
DaveMcLain- Posts : 399
» LUNATI custom solid roller cam ./SOLD
» 4.6 question
» Cam question...
» Oil Pan question
» 4.6 question
» Cam question...
» Oil Pan question
