1979 fairmont futura gear ratio
was wondering what gear ratio were in the above cars with a 255 inch windsor? Thats the small-bore 302 version.
thanks.
Al
thanks.
Al
72mav- Posts : 1081
Re: 1979 fairmont futura gear ratio
http://www.automobile-catalog.com/auta_details1.php WoW They are claiming 2.26's with a C4 trans. I figured it would be high but damn. I had a 79 Cutlass with 2.29's or 2.33's, so I am not real surprised.
supervel45- Posts : 4499
Sorry the link didn't work, but I pulled it up for a 1980 4.2L on the same site and came up with the gear ratio.
72mav wrote:was wondering what gear ratio were in the above cars with a 255 inch windsor? Thats the small-bore 302 version.
thanks.
Al
I had am '80 T-Bird with the 255 and man would that little bugger rev lol!! It had some real tall gears too so it took a while to get there.
Bill
billandlori- Posts : 2081
Thanks guys,
It was my old girlfreinds car, just a hundred dollar beater with a broken starter relay wire.
She later burned up the motor when a cracked valve seal locked up the oil pump.
Built a pre69 spec 2bl 302 with 4bl intake on it. Car was just spooky fast. A 50 cube difference dont make that much difference normally. Had to be gearing.
Thanks again.
Happy Holidays
Al
Thanks again.
Happy Holidays
Al
72mav- Posts : 1081
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» Pro Stock Trans gear ratio / Rear Gear
» Help with a gear ratio
» C6 Low Ratio Gear Set
» Gear ratio help
» Gear ratio help
