460 with dove head need advice
ragleone
I am new here on the site and new to big block fords. I am building a drag car . Here is what I have 460 30 over, stock crank, stock rods ARP bolts, forged flat top pistons the bottom end is done. Heads are Dove. I have not done anything to them I know they need porting but what valve size? what cam? I would like to run a solid tappet ? what intake? Would like to make 500 hp or I am way off?
ragleone- Posts : 10
Re: 460 with dove head need advice
Victor with a 1050 dominator
And a comp cam http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1021&sb=2
+Matching components
2.19 and 1.76 valves and some bowl blending
Thank you for the help. with the victor intake port match it to my heads? My car weights 2600 lbs
I had a 460 in my Ranger when I built it my 460 was standard 4.36 bore with flat top speed pro pistons, dove heads with home porting done by myself with 2.08 ss valves and 1.65 ss valves, victor intake, 1050 dominator carb, with a custom solid flat tappet cam from Randy Malik by the times slips it made 536hp with Wallace Racing Cals. truck wt 3265 et 6.72 1/8mile
Just a light match don't go crazy and hog everything out
J
J
69F100 wrote:I had a 460 in my Ranger when I built it my 460 was standard 4.36 bore with flat top speed pro pistons, dove heads with home porting done by myself with 2.08 ss valves and 1.65 ss valves, victor intake, 1050 dominator carb, with a custom solid flat tappet cam from Randy Malik by the times slips it made 536hp with Wallace Racing Cals. truck wt 3265 et 6.72 1/8mile
I hope I can make 536 HP
Leave the Victor manifold runners alone; just square-off the front and rear of the Dominator plenum and round the sharp edges.
Port MATCH the D0VE head intake ports at the flange to the manifold port locations..
dfree383 wrote:Just a light match don't go crazy and hog everything out
J
rmcomprandy wrote:Leave the Victor manifold runners alone; just square-off the front and rear of the Dominator plenum and round the sharp edges.
Doing these makes a work of difference and with the right cam, you'd be surprised what that motor will make
kjett- Posts : 1169
This was all I did to my intake Randy told me how to do it when I ordered the cam from him..
Thank you all for the help
on mine 429heads back in the 90's TO 2006, I pocket ported the intake only on the intake and did full port on the exhaust.THEY ran great to my 7200 rpms limit I had on my MSD BOX
rancheronut- Posts : 20
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» Boss head build. Need advice
» How much HP from a DOVE-C head on a 466 ?
» Dove C Head Damage
» Dove head question
