How much HP from a DOVE-C head on a 466 ?
+11
D. Sea
bluef100fe
85bigblockfox
nuclearcobra
kjett
Bret Powell
whitefield
15 posters
How much HP from a DOVE-C head on a 466 ? Empty How much HP from a DOVE-C head on a 466 ?
Post  whitefield November 5th 2012, 10:27 am
I started searching this and got tired of looking ,so decided to ask!
What is the most hp that has been made with these heads on a 13.5:1 compression 466 with good internals ?
I am trying to get an Idea of how much money and where I want to go with this engine. Thanks
whitefield
whitefield
How much HP from a DOVE-C head on a 466 ? Empty Re: How much HP from a DOVE-C head on a 466 ?
Post  schmitty November 5th 2012, 2:14 pm
I think there are several builders on this site that have done truck pull engines with DOVE heads that make serious power. I would bet that if the parts were properly matched one could get to 700 or possibly more HP.
Post  BOSS 429 November 5th 2012, 2:51 pm
On 460 ( yes stock bore) ,Dove heads stock stroke, solid cam,vic intake ,1050 carb(4500 dom) swap headers for a fox body@3000 have had the cars run 10.20s to 9.90s
this engine made around 600 to the wheels,most of the tests were at 1500 to 1800 feet of air
I should probably put this in the proven build section
Post  IDT-572 November 5th 2012, 7:01 pm
3000 lb, 466, flat top, flat tappet cam. C4, 4.10 gear, 10.35 @ 135 mph, 3500 conv. (too tight needed 5000) 60 ft 1.5's should have been 1.30 60's. Heads ported but not a very good job, 2.190 valve.
Jody's red 66 mustang, you know the car.
Post  whitefield November 5th 2012, 7:15 pm
BOSS 429 wrote:On 460 ( yes stock bore) ,Dove heads stock stroke, solid cam,vic intake ,1050 carb(4500 dom) swap headers for a fox body@3000 have had the cars run 10.20s to 9.90s
I would like to read more about it. My 466 is in a 3400lb car with out driver. Thanks
whitefield
whitefield
Post  whitefield November 5th 2012, 7:24 pm
IDT-572 wrote:3000 lb, 466, flat top, flat tappet cam. C4, 4.10 gear, 10.35 @ 135 mph, 3500 conv. (too tight needed 5000) 60 ft 1.5's should have been 1.30 60's. Heads ported but not a very good job, 2.190 valve.
Yes I do and if I remember it went 6.50 at the valley the last time I saw it run.
I would like to keep these heads add good rods,lighter pistons, solid roller cam, vic intake, and a 1050cfm carb. let me know if you guys think that it will be worth it. I would like to run as much of this engines parts as possible to cut down on cost. If that is possible!
whitefield
whitefield
Post  bbf-falcon November 5th 2012, 8:58 pm
Harolds 466 @13.5.1 ,C9's w/big valves and some home porting(no flow bench).car was close to 3000# w/him.It ran some 5.90's or maybe faster.
Post  whitefield November 6th 2012, 2:40 pm
bbf-falcon wrote:Harolds 466 @13.5.1 ,C9's w/big valves and some home porting(no flow bench).car was close to 3000# w/him.It ran some 5.90's or maybe faster.
Which head is better C9 or Dove-C ?
whitefield
whitefield
Post  bbf-falcon November 6th 2012, 3:21 pm
Same head different #'s
Post  BOSS 429 November 13th 2012, 11:52 pm
what would you like to know about this one?
Post  whitefield November 14th 2012, 7:04 pm
what rear gears tire size cam lift ect . Not wanting to duplicate but use as a guide. Thanks
whitefield
whitefield
Post  BOSS 429 November 15th 2012, 12:16 am
we had tried a few diff gears, best was 4.11 overall with nos, cam ill have to look up,flat tappet 666ish lift @ the valve ,but dont quote me on that yet, if i think of it ill look tomorrow,tire was a 11.50x15 et street on this one
Post  whitefield November 15th 2012, 5:26 pm
Thanks I may be asking a lot more questions around Christmas time. Cool
whitefield
whitefield
Post  Bret Powell November 16th 2012, 10:24 am
About 6 years ago I did a .060 over (472) D0VE headed deal for a puller, compression was closer to 14 to 1. Using a Pretty big C&S Dominator, Victor intake running on VP113. Just broke 750 around 7300 I believe. Heads were good, but could've been better.
Bret
Bret Powell
Post  whitefield November 16th 2012, 3:09 pm
Bret Powell wrote:About 6 years ago I did a .060 over (472) D0VE headed deal for a puller, compression was closer to 14 to 1. Using a Pretty big C&S Dominator, Victor intake running on VP113. Just broke 750 around 7300 I believe. Heads were good, but could've been better.
Bret
I would like to get close to that hp number with mine! Twisted Evil Cool
whitefield
whitefield
How much HP from a DOVE-C head on a 466 ? Empty Update
Post  whitefield May 20th 2014, 7:05 am
I got the old fairlane running, but made some changes . ! I changed from the stealth intake to a Vic. 460 intake . Changed from the c4 to the c6 , and changed from 3500 stall to 4500 stall speed converter.
Do you think these changes are for the better ?
whitefield
whitefield
Post  kjett May 20th 2014, 7:59 am
Look at proven build "466 in a ranger". Overall when it was said and tuned in, made 704hp @7200 with Freelander worked D0ve heads, Lem speced solid roller cam, ported FRPP "Victor" intake, 1150 dominator, and 2 1/8" headers
kjett
kjett
Post  IDT-572 May 20th 2014, 9:05 am
Yes , you made more power and less headache.............
Post  whitefield May 20th 2014, 10:51 am
Spacer for carb or no spacer ?
whitefield
whitefield
Post  kjett May 20th 2014, 11:02 am
I used a 1" Jomar Power cone under the carb with the 1/2" thick nitrous plate under that.
kjett
kjett
Post  whitefield May 20th 2014, 2:55 pm
kjett wrote:I used a 1" Jomar Power cone under the carb with the 1/2" thick nitrous plate under that.
I have a supper succker from quick fuel ! yes no maaybe ?
whitefield
whitefield
Post  IDT-572 May 20th 2014, 2:58 pm
Yes............. Worth around 15 hp on an average. More in some cases.
Post  nuclearcobra May 21st 2014, 7:52 am
my old combo ran a best of 10.57 at 128mph , it was a 472'' with ported c8 heads, stealth intake, 850 holley and the old heavy trw dish pistons #2404 , small flat hyd cam (comp 292) and a tci 11' converter that I couldn't foot brake over 1500 , the springs on the heads were comp 926 single that sat for over 10 years without the rockers backed off , and the c6 I pulled from a old box van had some good flair to it, all in all I think it did ok for what it was , weight was 2770 with me and 3.90 gears on a 28x10 slick.
nuclearcobra
nuclearcobra
Post  85bigblockfox May 21st 2014, 2:46 pm
Mine is a .030 over with trw 2443 pistons, stock rods, crank, small solid roller lift is .631 cant remember the rest, ported c9 heads with bigger valves, 4500 vic intake, 1050 holley. C6 with a UCC converter and at 3385lbs it runs 10.90s@123 with a 1.57 60'. This is in a 1985 mustang gt.
85bigblockfox
85bigblockfox
Post  whitefield May 21st 2014, 4:02 pm
I am hoping for 6:50 1 /8 mile at or around 104 106 mph on just the motor.
whitefield
whitefield
