How much HP from a DOVE-C head on a 466 ?
+11
D. Sea
bluef100fe
85bigblockfox
nuclearcobra
kjett
Bret Powell
whitefield
15 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: How much HP from a DOVE-C head on a 466 ?
I did a 472 13:1 solid roller dove heads victor intake 1050 dominator 2 inch header 3.5 collector... It dynoed 667 hp at 6600-6700 rpm... The heads were good but not full boogie... Just another reference point for ya
bluef100fe- Posts : 379
My cam as of right now is a comp hyd flat tappet cam . It is only good to around 6500 6800 rpm.
Traction is going to be a problem I am thinking . I hope to make some passes in it next weekend.
whitefield- Posts : 2244
whitefield wrote:I am hoping for 6:50 1 /8 mile at or around 104 106 mph on just the motor.
whitefield wrote:My cam as of right now is a comp hyd flat tappet cam . It is only good to around 6500 6800 rpm.
Not to sound like a downer, but a hyd flat tappet it going to be hard pressed to get you to the hp level you want to hit those numbers. A custom solid roller ground to match my specific heads it what it took to get my little 466 to where it was.
kjett- Posts : 1169
kjett wrote:whitefield wrote:I am hoping for 6:50 1 /8 mile at or around 104 106 mph on just the motor.whitefield wrote:My cam as of right now is a comp hyd flat tappet cam . It is only good to around 6500 6800 rpm.
I know you are telling me right ! I just didn't want to start taking it apart . I traded my 521 rotating assebly for the complete engine so I could get the Fairlane going.Thanks
Good luck next weekend Mike.
D. Sea- Posts : 2768
No hp numbers but I went 12.04 108 and 10.85 120 on 82 squared a few years back in my 4200lbs truck. 466 9.5:1 2404 pistons, ported d0ves, victor not gasket matched, 850, comp hyd flat tappet xe284h, 1 7/8 headers, 3.70 gears.
tfsbbf466- Posts : 180
Mike,
Did you ever run your car?
I did not ! I ran into some oil PSI problems !
I am planning on pulling the engine this next week an trying sort it all out .
Sounds good. Let me know what you find
I will ! Since it will be out I will be changing the camshaft !
Glad you kept it..............
You going back tappet or roller?? I vote solid roller bet it would pick up 30hp then a dominator swap we looking at 50hp jump
gmsmkr- Posts : 1364
Solid roller !
whitefield wrote: I got the old fairlane running, but made some changes . ! I changed from the stealth intake to a Vic. 460 intake . Changed from the c4 to the c6 , and changed from 3500 stall to 4500 stall speed converter.
Do you think these changes are for the better ?
If the cylinder head or manifold intake ports were somewhat matched with decent port alignment ...
certainly.
Although a well set-up C4 would be faster, it wouldn't last as long.
In my old dragster, I used to run 514's with D0VES and Offy Portosonic. Pushed the car to 5 teens. Never dyno'd but the calculator said ~ 750hp.
Curt- Posts : 2791
Page 2 of 2 • 1, 2
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» how much lift can i use on a dove head with out
» Dove head question
» 460 with dove head need advice
» Dove C Head Damage
Page 2 of 2
