CSR Waterpump Measurement
CSR Waterpump Measurement  Empty CSR Waterpump Measurement
Post  FalconEh January 24th 2016, 11:50 pm
Looking for the measurement flange to flange on a 460 CSR waterpump measured from the "pump portion" inside to inside of the flanges where the pump sides bolts to the arms.
CSR Waterpump Measurement  Empty Re: CSR Waterpump Measurement
Post  70FB January 25th 2016, 11:49 pm
Hold tight.
70FB
70FB
Post  70FB January 25th 2016, 11:51 pm
Csr pump, 35 gpm I think. I held an inch on it so it's actually just about 6-1/4".
CSR Waterpump Measurement  IMG_1083_zpsbltacsmw
70FB
70FB
Post  FalconEh January 25th 2016, 11:59 pm
70FB wrote:Csr pump, 35 gpm I think. I held an inch on it so it's actually just about 6-1/4".
Thank-You!
For the record I made a custom block plate for the Cleveland using the windsor pump which is the same measurement as the BBF.
Post  70FB January 26th 2016, 12:19 am
Thank-You!
Sweet. I have a friend that runs Clevelands. I'll pass that along.
70FB
70FB
Post  FalconEh January 26th 2016, 1:07 am
Thank-You!
Actually I was looking at it from a different direction, when I did the Cleveland plate there wasn't one available soon enough for the 351C, so I bought the SBF windsor figuring I could make it work, all it needed was a custom block plate, but now I need it for a BBF I wanted to know if it was likely I could make spacers or shims and recycle the SBF pump to the BBF I do believe the answer is yes.
