Engine Mock up Question
Can I use Dove heads on block to mock up motor plates and headers hooker 2" if my race engine has alum. motorsprt a460 CJ's. ? are the exhaust ports in the same location?
Threed247- Posts : 7
Re: Engine Mock up Question
Will work fine
Send me the doves when your done mocking up I'll get them out of your way to make room for the big bad boy alum. CJ's I hope they have the bigger valves if not could you have them installed before you ship thanks
Super Snake Steve- Posts : 141
Your post is confusing...
Your head is an aluminum A460 CJ? If so, then mocking up with the DOVEs is a waste of time due to the A460 and the DOVE having two different exhaust port locations and flange patterns.
Which heads are on your race engine? Aluminum CJ style heads, or A460?
jbozzelle- Posts : 3705
» Engine build question??? a little more help , Please!
» Engine build Question.....
» Engine Masters question
» Another question about engine plates ,
» ENGINE COMBO QUESTION
