Engine Masters question
LivermoreDave
2Strokerguy
I was looking at the engine masters summaries and I notice that Jon Kasses 2 engines both have the same bore and stroke, is that a misprint or is the Boss motor built way under square. If it is correct it sure points out major low end power in the mod motor. Just something I found and was curious about. JOHN
2Strokerguy- Posts : 18
Re: Engine Masters question
I'm not sure of the Boss 9 engine, I think the overhead cam engine was 3.7" bore and 4.70" or 4.75" stroke. I think the overhead cam deal was 409 CI.
Dave.
Dave.
LivermoreDave- Posts : 972
Displacement is displacement......
Cant agree w/ya there Dave.dfree383 wrote:Displacement is displacement......
Thread hi jack. Strokerguy, tell me about the sled in your avatar.
Mike R- Posts : 1381
A fairview sled
It was built to win the Fairview run what you brung shootout a few years back. It is a complete custom hanbuilt with only 3 stock parts on it. The motor is 2 cat 900s cut and welded together with PSI 98mm pistons for 1720 cc it also has two fogger nitrous systems on it. JOHN
2Strokerguy wrote:I was looking at the engine masters summaries and I notice that Jon Kasses 2 engines both have the same bore and stroke, is that a misprint or is the Boss motor built way under square. If it is correct it sure points out major low end power in the mod motor. Just something I found and was curious about. JOHN
Call Kaase's and ask them ...
» question about engine masters
» Engine Masters 414" stroker 351W street/strip engine
» Engine Masters 534 Boss Engine and BBF 72 Torino in the new PHR Magazine.
» Engine masters????
» Engine Masters Challenge?
