To check bearings or not....
BigRigTech
To check bearings or not.... Empty To check bearings or not....
Post  BigRigTech February 14th 2016, 6:28 pm
With a good running engine, good oil pressure and clean oil filters considered - how often do you guys with stock blocks/cranks check the bottom end? I'm turning my 472" 6500-7000 in good air, it has about 70'ish passes on it since the dyno. I was going to pull the engine anyways to take the tranny over for a free checkup (my tranny sponsor wants to see it every winter on his dime Wink ) and fix a pesky tranny leak.
BigRigTech
BigRigTech
To check bearings or not.... Empty Re: To check bearings or not....
Post  dfree383 February 14th 2016, 7:00 pm
Gaskets are cheap, if it's out I'd take a quick peak and check over the valvetrain too.
Post  BigRigTech February 14th 2016, 7:41 pm
This is true...I'd just hate to create a leak that isn't there now LOL...I check my valve-train after every race.
BigRigTech
BigRigTech
Post  dfree383 February 14th 2016, 8:38 pm
BigRigTech wrote:This is true...I'd just hate to create a leak that isn't there now LOL...I check my valve-train after every race.
Pull the lifters..... And inspect the cam too
Post  BigRigTech February 14th 2016, 8:52 pm
It's a SFT deal but I suppose I could take a peak.
BigRigTech
BigRigTech
Post  69F100 February 14th 2016, 9:44 pm
I checked mine every winter on my 460 now that I have the new front end it is easy to check the bottom end jack it up and put it on jackstands and drop the pan
Post  bbf-falcon February 14th 2016, 11:07 pm
dfree383 wrote:Gaskets are cheap, if it's out I'd take a quick peak and check over the valvetrain too.
X2
Post  cool40 February 14th 2016, 11:13 pm
If the filter is always clean I wouldn't fix what ain't broke. Cool
Post  BigRigTech February 14th 2016, 11:51 pm
I started running Jomar filters last summer and the first one I cut open was clean too.
BigRigTech
BigRigTech
Post  supervel45 February 14th 2016, 11:59 pm
cool40 wrote:If the filter is always clean I wouldn't fix what ain't broke. Cool
X2 and what are you going to look at on a SFT if lash is good. Don't wear out the bolts.
Post  BigRigTech February 15th 2016, 12:34 am
I guess I'll see what the filter on it now says and go from there.
BigRigTech
BigRigTech
