New motor ready for mustang
gt350hr
gmsmkr
glenevans
New motor ready for mustang Empty New motor ready for mustang
Post  glenevans March 8th 2016, 3:21 pm
New motor ready for mustang 20160302_232719_zpszzgymrz4New motor ready for mustang 20160306_160144_zpsnajwfu2fNew motor ready for mustang 20160306_184506_zpstwgncfky
New motor ready for mustang 20160306_220653_zps2vl5h7cm
glenevans
New motor ready for mustang Empty Re: New motor ready for mustang
Post  supervel45 March 8th 2016, 4:03 pm
Love it. 429 sure. Cool
Post  glenevans March 8th 2016, 4:06 pm
Ha Ha, chevy and mopar guys don't know the difference!!!
glenevans
Post  gmsmkr March 8th 2016, 5:22 pm
Where did you get the alternator mount and what style alternator you got I need a deal like that
gmsmkr
gmsmkr
Post  glenevans March 8th 2016, 5:36 pm
It is a stock ford two piece mount off of a 400 or 460, don't remember. Alternator is a GM 1 wire, 10si I believe, rebuilt to 100 amp, goes to 6ga wire to trunk mounted solenoid or cutoff, have to look tonight. Thinking of going back to 3 wire alternator because volts go down quite a bit when fuel pump, fans, lights, waterpump are all on. The 1 wire setup does not maintain 14v like "normal" when engine is running. Am using a ford contour v6 dual fan setup, fits early mustang radiators nicely, have each fan wired to a toggle separately. I think the alt bracket came from the 1971 LTD wagon 429 I originally swapped into the car back in 1983.
glenevans
Post  res0rli9 March 8th 2016, 6:16 pm
glenevans wrote:It is a stock ford two piece mount off of a 400 or 460, don't remember. Alternator is a GM 1 wire, 10si I believe, rebuilt to 100 amp, goes to 6ga wire to trunk mounted solenoid or cutoff, have to look tonight. Thinking of going back to 3 wire alternator because volts go down quite a bit when fuel pump, fans, lights, waterpump are all on. The 1 wire setup does not maintain 14v like "normal" when engine is running.  Am using a ford contour v6 dual fan setup, fits early mustang radiators nicely, have each fan wired to a toggle separately. I think the alt bracket came from the 1971 LTD wagon 429 I originally swapped into the car back in 1983.
Yes thats a early 429 alt. brk. with short w/p
Post  gmsmkr March 8th 2016, 6:31 pm
Thanks for the info... good looking engine
gmsmkr
gmsmkr
Post  supervel45 March 8th 2016, 6:52 pm
My 1972 429 alt. bracket looks like that to. Thanks for the tip on the water pump, I better bring it with me when I go to get the new one, always suspected it was the short one with the fan so close to the A/C compressor.
Post  glenevans March 8th 2016, 6:57 pm
Thanks. I feel like I built 2 or 3 engines with how many times we had this one together and apart. Guys that build engines for living have to really know their stuff to do it efficiently.
glenevans
Post  glenevans March 8th 2016, 7:02 pm
I run the alt belt on the very inside crank pulley, the stock damper was not the grooved style like the short w/p has (on this setup)
glenevans
Post  gt350hr March 8th 2016, 7:50 pm
gmsmkr wrote:Where did you get the alternator mount and what style alternator you got I need a deal like that
460 in F150-F350 , probably more applications . My '78 has one and I got a spare at the junk yard.
gt350hr
Post  glenevans March 8th 2016, 8:31 pm
Thanks to all for the help, all my previous motors were iron headed flat tappet builds
glenevans
Post  res0rli9 March 8th 2016, 8:51 pm
The short w/p's came on I think 70 down with the pulley made into the damper. Mine is a 69.. the rest with that brk. used longer spacers.
Post  wayney March 8th 2016, 9:23 pm
Good looking motor...... any details on the build?
wayne
wayney
Post  Lem Evans March 8th 2016, 9:26 pm
Pretty Cool deal Exclamation
Post  glenevans March 8th 2016, 9:59 pm
4 bolt Dove-A block, 4.39 bore, zero decked, Lunati forged 4.500 crank, scat H-beam rods , arp 2000 bolts, flat top auto tech pistons, 14-1 compression, solid roller cam .760 lift 276° duration cam pinned and bigger bolt w/roller bearing, stock P-51 heads, Crower ss 1.73 rockers, mafia intake smoothed a bit, holley 1150 carb, deep sump pan with Kaase aluminum pump and canton windage screen, innovators west damper , moroso electric water pump , .137 wall 3/8 pushrods. 8" converter, 1969 mach 1, 4400 ft elevation. Whew!!!
glenevans
Post  glenevans March 8th 2016, 10:21 pm
The elevation is the kicker, lose about 13% of power right off the bat.
glenevans
Post  dirt_worker March 11th 2016, 12:29 am
Cant wait to hear some results.
Thats almost the exactly the engine that cam came out of.
Youre gonna be a VERY happy man the first day you drive it Wink
dirt_worker
dirt_worker
Post  glenevans March 11th 2016, 12:53 am
Really looking forward to feeling some power finally. Thanks for parts Mike!!! Hope we can make it up to Boise this year.
glenevans
Post  supervel45 March 11th 2016, 1:05 am
So did you have the heads ported or did you bolt them on out the box? It's should make a ton of power either way.
Post  glenevans March 11th 2016, 1:18 am
Heads are unported. My plan was to get it running for couple years, then when doing freshen up, have heads and intake ported and maybe get bigger cam.
glenevans
Post  supervel45 March 11th 2016, 1:30 am
10/4. Hey on a different subject have you had problems with PhotoBucket loading pictures and do you know of a different way or if someone else can post them somehow or can it be done from a cellphone? My kid does all this kind of stuff for me and he could not come up with a way.
Post  glenevans March 11th 2016, 1:53 am
Unfortunately I am not very helpful with this stuff. The guy that helps me does it by opening a photo bucket app on my phone and then sign in on computer. Then you have to "move" the photos you want to "your bucket". Then click on the bottom direct link , control c (copy) then while on this website (429-460.com) you click the small blue box, then control v (paste) . I have the actual step by step at work, so this may be wrong, will check tomorrow or Saturday when I am back there
glenevans
Post  supervel45 March 11th 2016, 2:00 am
Thanks. The pictures loaded on the cell prone from photobucket but not the laptop. Had a lot of rain today and laptop kind of sketchey, don't really know what is going on. Could you hit the chatbox for a second if you have time please?
Post  supervel45 March 11th 2016, 2:02 am
Second too slow, I'll catch you tomorrow. I thought you logged off hit the chat box if you can.
