engine mount bracket
engine mount bracket Empty engine mount bracket
Post  Bart Knox April 4th 2016, 8:38 pm
I've been searching around for 80-96 f250 engine mount brackets with no luck. I've looked at LMC the dealership and every big scrap yard around and nothing. its like there isn't any in Canada. Is there somewhere to buy new or a suggestion where to look.
Bart Knox
Bart Knox
http://W. B Knox&son LTD Huntsville Ontario
engine mount bracket Empty Re: engine mount bracket
Post  supervel45 April 4th 2016, 9:14 pm
Just get a set of 351 adaptor mounts and chain the engine down on the torque side. They will hold up for awhile.
Post  Bart Knox April 4th 2016, 10:09 pm
I would like to get factory stuff mainly because you cant get anything from Canada but I guess I'll go with L&L or south coast I think were the other ones I was looking at. I was going to get this kit from ebay but buddy won't email me back
Bart Knox
Bart Knox
Post  Bart Knox April 4th 2016, 10:10 pm
engine mount bracket _1-111
Bart Knox
Bart Knox
Post  supervel45 April 4th 2016, 10:23 pm
I don't know that much about the 80's-90's trucks but I do know the 70's big block factory mounts and pearchs where/are hard to get and pricey. That is why I went with the conversion mount's for a $100.00 dollars back then. Wish I could help you more.
Post  SandHillsHillbilly April 5th 2016, 8:31 am
Those adapter plates are scarce as hen's teeth. I don't know why I guess everyone just tossed them not thinking about factory availability later on. Someone was making billet plates at one time, but I recently checked and he is no longer making them.
Best option for you is the Autofab mounts. They use a replaceable poly bushing. Should be easy to get shipped to Canada and anyone can make replacement bushings if ever needed. Autofab makes some of the toughest parts that are actually competition tested and proven.
http://autofab.com/c-335581-engine-motor-mounts-heavy-duty-competition-style-80-96-f150-bronco.html
SandHillsHillbilly
SandHillsHillbilly
Post  supervel45 April 5th 2016, 2:09 pm
^^^^^ They better be for $390.00 bucks. Break out the welder Bart.
Post  Mustang-junky April 5th 2016, 10:10 pm
So you need more than just the mounts to swap a 460 into a 80-96 F series truck? I have a 1987 f-350 I plan to pull the 6.9 diesel and swap in a 460 this summer. I figured since the 460 was offered in for my truck it would be a simple deal. Am I wrong?
Jess
Mustang-junky
Mustang-junky
Post  Bart Knox April 6th 2016, 6:37 am
$390 is over $650 by the timeI get them here... I would like to no the same as you Jess if the diesel engine mounts would work I am going to get a parts truck for my 92 diesel for $400 Canadian would be nice to kill two birds with one stone. I was told the blocks were similar.
Bart Knox
Bart Knox
Post  Mustang-junky April 11th 2016, 9:01 pm
Diesel perches are different too. I will probably end up buying the ones that Jeff's Bronco Graveyard sells.
http://shop.broncograveyard.com/460-Mts-Diesel-1983-90/productinfo/30909/
engine mount bracket 80upmotorstands
Jess
Mustang-junky
Mustang-junky
Post  Bart Knox April 12th 2016, 5:26 pm
Those perchs are the same as small block and the mounts are swap mounts? I would just need those mounts?
Bart Knox
Bart Knox
Post  Mike R April 12th 2016, 8:06 pm
Bart, here's the link to their contact info http://broncograveyard.com/contact.html send them an email explaining what you're trying to do Very Happy
