SFT to solid roller. Let's hear it.
+6
gmsmkr
Carl
BigRigTech
10 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: SFT to solid roller. Let's hear it.
http://miramichidragwaypark.com/
BigRigTech- Posts : 763
BigRigTech wrote:I hear ya there. I'm kinda partial to these old A429 heads so I'd like to see more HP squeezed from them. Should I get something off the shelf for a cam or a custom deal?
Personally, if I was in your shoes, I would get a better "custom ground" Flat tappet, Solid lifter cam with the correct EDM lifters to be a better fit with your converter and what you wish to do.
Spend the effort to change valve springs to break-it-in right and move forward from there.
THAT is the most "Bang for the Buck", given your present combination.
Just to give you an example of what you can get. I have a 467 with custom Diamond pistons with a 10cc dome, GRP rods, 429 truck crank offset ground to 2.200 rods and 3.85 stroke. A429 heads that don't match your flow numbers on intake. .728lift with 270-276 duration roller on a 110 centerline. Mafia intake with a Rons Terminator. Glide with 4.10 gears and 2940lb car with me and the car has been 5.69 in 1/8 and 8.95 in the 1/4 @ 151.23mph. Heads are certainly not the best flowbench queens but they make big hp when the combo is right. Converter is not right as evidence of a 1.43 short time. Mine is 1.26-1.28. Just some food for thought.
514Fox87- Posts : 436
My 60ft times are fudged and misleading. The car had SSM bars, NO ARB, stock V8 rear springs and SA strange shocks last summer. It hit the tires really hard and bounced. That's why I bought all the new rear suspension stuff to see if we can get it to leave better. My car weighed 3022lbs last summer with me in it. Watch the video and you will see awkward it was. Most runs it goes 106-108mph in the 1/8th and I'm just shifting to 3rd right before the 1/8th mile marker.
https://www.youtube.com/watch?v=HIpYJVKiqqM
https://www.youtube.com/watch?v=vfdjGwJ1onM
https://www.youtube.com/watch?v=SXFkynJaYlY
Page 2 of 2 • 1, 2
» BBF SOLID ROLLER CAMSHAFTS AND ONE SET USED COMP CAMS SOLID ROLLER LIFTERS
» N/A Low 5's doable Yes or No Lets Hear It
» Using Hydraulic roller lifters on the Comp XR292 R-10 Xtreme Energy Solid Roller cam?
» Hydralic roller compared to solid roller
» JT557 HERE NEED SOLID ROLLER LIFTERS FOR ROLLER CAM
Page 2 of 2
