piston clearance?
Carl
james00
piston clearance?
is 8 thousths too much piston to wall clearance on a 460
james00- Posts : 14
Re: piston clearance?
Depends on what the piston is made of, and how it will be used.
Carl- Posts : 284
Seems awfall big. Whats the application, bore and piston MFG?
paperman- Posts : 88
The manufacturer is most important. That determines where it is measured and what it should measure.
gt350hr- Posts : 662
Is it where it should be? No, but will it work and be noisy, yes.
I have ran them that loose and more, with a file fit ring to get a good ring seal.
The bore being round is of more concern to me, if it's worn that much and not a screwed up boring job.
Just up to you, on how good of a rebuild you want or need. Probably ain't going to be a 100,000 mile engine.
Hey , just my two cent's worth...............
What application, kind of piston material, and exactly where are you taking your measurement?james00 wrote:is 8 thousths too much piston to wall clearance on a 460
they are trw forged pistons. i am taking measurements about an inch from the bottom of the skirt.this is just a street engine the pistons have been milled to flat tops. 5 of them have 5 thousands clearance and 3 of them are 8 thousands thanksPaul Kane wrote:What application, kind of piston material, and exactly where are you taking your measurement?james00 wrote:is 8 thousths too much piston to wall clearance on a 460
james00- Posts : 14
james00,
If you are going to use them . Put the smallest pistons in #1 and 5 cylinders and the third "small one" in #2. Because of water flow in and out of the block this will be the best location for them. Paul is right , they are loose , but they are not loose enough to cause failure of the piston itself.
In addition to the latest post above and to be prudent, I suggest you first remeasure a cylinder bore(s), and also that you very carefully and consistency measure your piston skirts again and in the exact same location on each piston. You might have 5 good pistons (0.005") and 3 pistons (0.008") with collapsed skirts. This assumes you are measuring used pistons. If they are new then you may disregard this post...but try to take more precise measurements.james00 wrote:
» Anyone know how close the Forged L2366f piston is to cast 429 piston?
» Piston ???
» Piston?
» f/s 1 trw-l2404 .030 pistion
» Piston
» Piston ???
» Piston?
» Piston
