Head Gasket recommendations
Hello, rebuilding my 460 cast stock block with cast stock heads with .030 over forged pistons and wondering what head gaskets I should be using. I am running 150 shot of NOS. In the past I have always used Fel-pro gaskets with great luck. After 8 years of running the head gasket's were leaking coolant into the crankcase (very slowly). I am wondering if there is a better choice of head gasket for my application. Any and all replies will be greatly appreciated. Thanks, -Ed
Sheermadness77- Posts : 11
Re: Head Gasket recommendations
I used the felpro 1018 with a 200 shot.
68formalGT- Posts : 865
+1 Fel Pro 1018 works. Cometic for more extreme situations.
gt350hr- Posts : 662
Sheermadness77 wrote:Hello, rebuilding my 460 cast stock block with cast stock heads with .030 over forged pistons and wondering what head gaskets I should be using. I am running 150 shot of NOS. In the past I have always used Fel-pro gaskets with great luck. After 8 years of running the head gasket's were leaking coolant into the crankcase (very slowly). I am wondering if there is a better choice of head gasket for my application. Any and all replies will be greatly appreciated. Thanks, -Ed
I have used the standard Blue Felpro PTP's in my deal with the same amount of nitrous at 8.5/1 compression with no problems. Going back with them again and could have done 1018's for not much more but, did not see a reason to change. When I do my 10/1 big nitrous engine I am going with 1018's though.
supervel45- Posts : 4498
» Head Recommendations
» ALUMINUM CYLINDER HEAD RECOMMENDATIONS ??
» when to use an mls head gasket.
» Head gasket
» Blown head gasket
» Head gasket
» Blown head gasket
