ALUMINUM CYLINDER HEAD RECOMMENDATIONS ??
SLOWnSTEADY
Wayne Pearce
Hey, Guy's: I'm at the point of wanting to replace the D0VE-C cylinder heads on the 460 in my 30 Model A Coupe street rod. In the interest of weighing less, and a little bit more octane tolerance, I"m at the point of saying "just what do I want"? First of all, it's not a drag race motor - basically it's just a street rod cruiser, with a little extra power. D9TE block, stock bore, and stroke, stock early rotating assembly, Crane Hydraulic cam similar in spec. to the 429 CJ hydraulic, and a Blue Thunder 2X4 set up with Edelbrock carbs. I've been looking at the Edelbrock aluminum heads, and never realised that there's three to pick from, so - what do you guys recommend, something other than the Edelbrocks? Just don't say "Procomp"!! (LOL)
Wayne SAWDOFF) Pearce
Wayne Pearce- Posts : 658
Re: ALUMINUM CYLINDER HEAD RECOMMENDATIONS ??
TFS streets if you don't want to change pistons But the Eddy's will do just fine on the street
![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif)
Another vote for the TFS Streets. Good Stuff !!
With that small cam the SCJ heads may go on w/o redoing the intake valve relief. Is this a dished piston?
SLOWnSTEADY wrote:ProComp![]()
I know he didn't want to hear it but, that IS the exact purpose of those heads ... they are not a race head.
They are large combustion chamber though and he seems to need a small combustion chamber.
I'd use a set of Blue Thunder CJ heads cleaned up a bit.
Bret
Bret
Bret Powell- Posts : 133
I just bought the set of TFS streets that "70429SCJ" had for sale. I'm just waiting for the delivery.
Wayne (SAWDOFF) Pearce
That was a good deal.
res0rli9- BBF CONTRIBUTOR
» Head Recommendations
» Head Gasket recommendations
» Aluminum cylinder head repair?
» Cylinder Head for 500+ ci.
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
